recommended pump speed arctic cooling LF 240
Discussion in 'Overclocking & Cooling' started by sirmonkey1985, Jan 12, 2018.
  1. sirmonkey1985
    sirmonkey1985 [H]ard|DCer of the Month - July 2010
    19,809
    Sep 13, 2008
    so i just recently bought the arctic cooling liquid freezer 240 and friggin love it but the pumps the loudest thing about it.. i've been trying to figure out what the recommended pump speed should be on it(currently 5400-5500rpm) but can't seem to find anything on recommended pump speeds. was hoping maybe others that might have this cooler have found a lower setting that works or if i should just leave it at default.
    fyi this is my first AIO cooler i've used so i'd rather ask a simple question like this then screw up and kill it and have to wait a week for a new one.
  2. VanGoghComplex
    VanGoghComplex Gawd
    776
    Apr 5, 2016
    Fire up a stress test, let your temperatures stabilize under load, and start backing the pump speed down until your temps are getting higher than you want them. *shrug*
    pendragon1 likes this.
  3. sirmonkey1985
    19,809
    Sep 13, 2008
    yeah that's what i was thinking of doing but never messed with these AIO's so wasn't really sure how sensitive the pumps were to rpm changes.
  4. VanGoghComplex
    VanGoghComplex Gawd
    776
    Apr 5, 2016
    Should be fine. I'm assuming you're using some AF software that lets you control the pump speed? (I'm not familiar with AF's AIO coolers.)
  5. Batboy88
    Batboy88 Limp Gawd
    175
    Dec 25, 2017
    Max pump speed like 2500rpm++
  6. VanGoghComplex
    VanGoghComplex Gawd
    776
    Apr 5, 2016
    Erhm... what?
  7. Batboy88
    Batboy88 Limp Gawd
    175
    Dec 25, 2017
    well depends on what pump...something like the aio's corsair pump spin like 5000rpm etc
  8. VanGoghComplex
    VanGoghComplex Gawd
    776
    Apr 5, 2016
    ...yeah but what are you talking about? OP was asking what the minimum speed was they could safely run it, and they gave us the max speed of their pump.
  9. sirmonkey1985
    19,809
    Sep 13, 2008
    it's all good, a lot of his posts don't make much sense, lol.. i tried changing the rpm but it wouldn't budge from 5400rpm.. trying to change it lower would just cause the rpm reading to fluctuate between 5300-5450 so i just put it back to full speed and decided to spend time overclocking my processor to 3.9Ghz.. need to spend more time finding the lowest stable voltage(at 1.37v right now) but that'll have to wait til sunday night.
