recommendations needed for a good PCI slot or USB wireless network card
Discussion in 'General Hardware' started by peppergomez, Jun 11, 2018.
  1. peppergomez
    peppergomez Gawd
    629
    Sep 15, 2011
    Been using an ethernet cable for years now, but have moved and can't do so in my new place. Can anyone suggest a good card or USB plug in wireless device?
    I'm on Windows 10.
    Thanks.
  2. capt_cope
    capt_cope Gawd
    595
    Apr 12, 2009
    I've always had good luck with the Intel 7260 and 8260 cards, never really tried any of the USB options, so I can't recommend any of those.
  3. TheFlayedMan
    TheFlayedMan n00bie
    32
    May 29, 2015
    I was using a ASUS PCE-AC68 wireless card for a couple of years before I moved and went back to wired. I never had a problem with it but don't really know if there are better options out there.
  4. brucethemoose
    brucethemoose [H]Lite
    87
    Mar 3, 2018
    My TPlink Archer T9E has been fabulous so far. Not single issue so far, and the one I got for a sibling allegedly gets way more bandwidth over a congested connection than anything her roommates ever had.
    That being said, the chipset it uses is pretty old now. But you should still look into PCIe cards. Back when I was shopping, 3x3 or better USB wifi cards were impossible to find, and I think that's still the case, which gives the PCIe wifi cards a big advantage over their USB counterparts.
  5. pendragon1
    pendragon1 [H]ardForum Junkie
    9,478
    Oct 7, 2000
    intel and tplink are good. i used to really link dlink but haven't used anything wifi from them in years. tplink is on sale at amazon right now. $20-40 will get you one.
  6. vick1000
    vick1000 [H]ard|Gawd
    1,816
    Sep 15, 2007
  7. HiryuuX
    HiryuuX Limp Gawd
    151
    Jul 16, 2017
    capt_cope likes this.
  8. pendragon1
    9,478
    Oct 7, 2000
    ^ that's a good option, cheap too!
  9. peppergomez
    peppergomez Gawd
    629
    Sep 15, 2011
