Jan 31, 2017 #1 A AP2 [H]ard|Gawd Joined Jun 25, 2007 Messages 1,570 can anyone recommend a open wall mount rack with a maximum overall width of 19.5" ? I need to fit 2 side by side in a 39" space. Thanks!
Jan 31, 2017 #2 G goodcooper [H]F Junkie Joined Nov 4, 2005 Messages 9,771 well, like the internal dimensions need to be 19", so i'm not so sure you're going to get a legit rack... monoprice sells brackets check monoprice and navepoint.com.... between those two you'll be able to find what you need
Feb 1, 2017 #3 E Ehren8879 Supreme [H]ardness Joined Sep 24, 2004 Messages 4,499 You might be better off going with a pair of two or four post, open racks. Then fashion an enclosure for them if necessary. For example: http://www.dell.com/en-us/work/shop...ven1=ssTKOzzBs&ven2=,&ven3=470403543497377995 Your width might be tough to meet and 9U is rather non-standard. But 8U us an option. Good luck
Feb 3, 2017 #4 A AP2 [H]ard|Gawd Joined Jun 25, 2007 Messages 1,570 thanks for the recommendations. I ended up getting one startech 8u rack to test with. thanks again.
