After 20+ years of using only ASUS mottherboards in at least 8 system builds I need to find another vendor. Recommendations appreciated.
Important points are:
I am not an overclocker, so overclocking ability is a nice-to-have but not as important as the three points above. Price is not as important, because saving a few bucks isn't worth a lot of hassle when I'm building my rig or using it for years.
I just had a terrible support experience on behalf a a friend for whom I was building a system based on (his needs) a low-end motherboard. On the other hand, i'm about to build my next build, a "Photoshop killer" machine. I've done some preliminary research and I will get a motherboard that uses an 8-core Intel CPU, 64 GB of RAM (but can support up to 128 GB), a 1060-class graphics card with enough memory to drive a 4K display. I was intending to get a higher mid-range or even top-range ASUS board, but after this support experience, no way Jose.
x509
- overall build quality
- BIOS support long-term
- support utilities
x509
