[Recommendation] 120mm Case Fan with 100+ CFM
Discussion in 'Overclocking & Cooling' started by Landmine, Aug 20, 2012.
  1. Landmine
    Landmine Limp Gawd
    402
    Oct 19, 2011
  2. P4rD0nM3
    P4rD0nM3 [H]ard|Gawd
    1,544
    Jun 5, 2007
    The Delta brand - they go to 200+. Or Sanyo which can go up to 300+.
    Pretty sure I saw a 500 CFM heavy duty 120mm fan like a year ago.
    May I ask why 120mm? If you go bigger than that there's a ton more options and some could push more than 1000 CFM.
  3. Landmine
    Landmine Limp Gawd
    402
    Oct 19, 2011
    Any links? That's awesome buddy.
  4. I would also like to know why the 120mm limit, seeing as you are not using for a computer case, there are some 200mm+ industral fans you can get that will most a shit ton of air. You also said nothing about voltage or power supply, are you limited to 12v? Or can you run 110v/115v AC fans?
    Stay away from cheap fans like the one you listed, my guess is this fan will not be in a cool area like in a PC case, and you are looking at a sleeve bearing fan, not a good idea for the kind of environment you will be putting it in for any kind of life span. This would be much better, as it's an industrial fan, ball bearing and moves 140CFM and is only 4 bucks.
    If you are willing to do AC and larger fans, you could get something like this or this, which move almost 200CFM for pretty cheap.
  5. P4rD0nM3
    1,544
    Jun 5, 2007
