Recommend me a mechanical keyboard under $150.
Discussion in 'Mice and Keyboards' started by delvryboy, Dec 3, 2011.
  1. delvryboy
    delvryboy 2[H]4U
    2,486
    Feb 21, 2008
    I don't game much, basically none until I bought Civ5, so macro's aren't a must. It would be nice to have some programmable keys though.
    I was thinking the MX brown's would be best, but I'm not against the blues.
    Currently, I'm on the verge of buying the blackwidow ultimate, I really like the backlights. However, seems there are a lot of quality control issues.
    Also, saw this:http://www.amazon.com/XArmor-U9W-wi...?s=electronics&ie=UTF8&qid=1322942049&sr=1-18 ....I like the wireless.
    Opinions?
  2. Khanmots
    Khanmots Gawd
    905
    May 12, 2007
    I beleive the blackwidow ultimate is only 2KRO although it will give some more around WASD. Wouldn't work for me because of that as one of the primary reasons I'm looking at going mechanical is to get more than 2KRO. Also, be aware that blues have very disparate make and break points on the switch. Meaning you can't easily tap a key a lot as it takes a relatively lot of travel to reset the internals. If you still want blues I'd be tempted to say look elsewhere for a keyboard that is NKRO or at least 6KRO.
    Personally I'm going to purchase a Leopold with browns (or rather have it gifted for xmas).
  3. ThinJ
    ThinJ Gawd
    733
    Jan 20, 2007
    I think Browns are the best all around switch. They work great for gaming and typing both, and don't have the noise of the blues.
    It's where I started.
    I really like the board I have with red switches for gaming, but I kinda hate typing on it.
  4. delvryboy
    delvryboy 2[H]4U
    2,486
    Feb 21, 2008
    Yeah, I'm most interested in typing. What are your thoughts on the wireless board I posted. That uses the MX browns, not a lot of reviews though and I'm not familiar with the brand.
  5. ThinJ
    ThinJ Gawd
    733
    Jan 20, 2007
    No idea. As a rule, I tend to just not bother with wireless input devices for anything other than my home theater box.
  6. xSalvation
    xSalvation Limp Gawd
    238
    Oct 31, 2010
    Filco's are usually referenced as the best brand.I prefer to stay away from razor because they use low quality materials.
  7. shawnoen
    shawnoen [H]ard|Gawd
    1,565
    Apr 21, 2009
    Filco Majestouch2.
  8. skizzled
    skizzled [H]ard|Gawd
    1,944
    Nov 13, 2007
    Yeah, I'm loving my Filco 10keyless Majestouch 2 with Browns.
    If you are wanting macros and other functions, you can use a program called AutoHotKey. Granted, the "interface" isn't as "slick" as say Razer's but it lets you program keys to do what you want them to do. You'll just have to learn some very simple programming.
    I have AutoHotKey set up with using the right function key + F9-F12 to control music playback. Never really had issues.
  9. delvryboy
    delvryboy 2[H]4U
    2,486
    Feb 21, 2008
    I think I'm going to go with the Filco. I really like those backlit keys, but can't really get beyond all the bad quality reviews
  10. DirtyB
    DirtyB Gawd
    832
    Jun 30, 2007
    I enjoy my Leopold 10keyless with browns quite a bit. I went with it over the Filco solely for the cost savings because it was my first mechanical keyboard. Can't say I'm disappointed.
  11. Bomo
    Bomo Gawd
    902
    Mar 9, 2010
    Filco 10 keyless Majestouch 2 with Browns is what I've got as well. I love it. I am curious about blue switches now though, but not enough to buy another keyboard right away. Maybe if I can find a display keyboard in a store somewhere to play around with...but until then I'll probably stick with the browns. I absolutely love this keyboard.
  12. compslckr
    compslckr [H]ardForum Junkie
    8,878
    Jun 5, 2002
  13. Dev1ant
    Dev1ant Gawd
    646
    Jul 16, 2007
  14. herfalerf
    herfalerf Gawd
    698
    Jul 17, 2010
    Xarmor has quality control issues. The regular bw has less issues than the ultimate. Honestly there are an overwhelming number of good choices.
  15. delvryboy
    delvryboy 2[H]4U
    2,486
    Feb 21, 2008
    Hmm. Ducky vs. Filco?
    I think I'm going with the blues anyhow.
    I'm about to pull the trigger....
  16. delvryboy
    delvryboy 2[H]4U
    2,486
    Feb 21, 2008
    Blah. The Ultimate Stealth just came in stock a minutes ago. Halp!
  17. nsx241
    nsx241 Gawd
    687
    May 13, 2008
    Isn't x-amor (iOne) out of business? Last I checked, their site and customer support are non-existent.
  18. delvryboy
    delvryboy 2[H]4U
    2,486
    Feb 21, 2008
    If I go no BL, I'll go with the wasd. Backlit choices are between the Ultimate Stealth and the Ducky w/ browns, when it comes back in stock.
    I should of started a poll. Lol .
  19. ccm_vector
    ccm_vector n00b
    10
    Nov 17, 2011
  20. Ruahrc
    Ruahrc Limp Gawd
    445
    Mar 8, 2009
    Have you considered an MX Clear board? Personally, for heavy typing, I'd go with clears or blues rather than browns. The browns are really light, and it is very easy to bottom out especially when you are typing at speed. This constant bottoming out nullifies most of the noise advantage that the browns have over the blues, thery're still pretty loud if you bottom out all the time. In order to type without bottoming out, you will need an extremely light touch (for me, I find it hard to be this "gentle" while maintaining accuracy when trying to type rapidly).
    Clears are like browns but a with a stiffer spring more like a blue. The tactile "hump" is also a little more pronounced than the brown (which is pretty mild) but not as much as the blue (but more for haptic reasons). They have more resistance near the bottom of the stroke, so you don't have to be as careful when typing to avoid bottoming out. As a result it may make it quieter on the whole than a brown board. Also if you stop worrying about not trying to bottom out when typing fast, your speed/accuracy goes up. At least it did for me.
    Blues IMHO would have the best tactile response, since they not only have the most defined resistance "hump", but also your fingertip actually feels the vibration of the "click" as the switch mechanism is activated. The feeling of the vibration combined with the audible click are the most effective of all the switches in telling you when you have hit the actuation point. Personally browns don't seem that much quieter in terms of volume if you keep bottoming out, but mainly have a different frequency response (blues are more high pitched "clicks" as the switch mechanism activates (possibly combined with bottom-out "clacks"), browns are lower "clacks" as you bottom out).
    Ruahrc
  21. delvryboy
    delvryboy 2[H]4U
    2,486
    Feb 21, 2008
    Ended up with the BW Ultimate Stealth. I like all the extras it brings to the table.
    I looked into every suggestion here and learned a lot. I'm not a keyboard purist nor am I a gamer.... hell the only game I've played in the last 10 years is Civ5 and I don't even use the keyboard. I'm pretty sure my moderate use will be fine with this keyboard.
    BTW - I may pick up a WASD for work, they seem like an awesome start up and really seem to focus on quality.... definitely worthy of my $$$.
    Thanks for all the help.
  22. ironforge
    ironforge [H]ard|Gawd
    1,228
    Feb 7, 2006
    I was about to get a WASD keyboard.. but since I had the newegg $40 gift card I went with a rosewill 9000 with mx brown switches. So far so good.
  23. 100inch
    100inch Limp Gawd
    254
    Mar 6, 2010
    blackwidow = xArmor.
    Wireless is probably not going to happen.
    Stick with the known quality brands. Filco/leopold/ducky/ etc.
  24. delvryboy
    delvryboy 2[H]4U
    2,486
    Feb 21, 2008
    ? Confused on both accounts.
  25. 100inch
    100inch Limp Gawd
    254
    Mar 6, 2010
    blackwidow is made by xarmor
  26. delvryboy
    delvryboy 2[H]4U
    2,486
    Feb 21, 2008
    Xarmor isn't an OEM.
    I really didn't get the wireless thing either.
  27. 100inch
    100inch Limp Gawd
    254
    Mar 6, 2010
    you know what i meant. i cancelled out the equals sign with words and it made it false
  28. delvryboy
    delvryboy 2[H]4U
    2,486
    Feb 21, 2008
  29. ThinJ
    ThinJ Gawd
    733
    Jan 20, 2007
