Recommend me a case to replace my S320 Elite which is causing heat issues
NIZMOZ
With my AIO 240mm Kraken X62 in the front, my CPU temps are high when playing and I get alerts. If I remove the glass off the side, it drops over 20 degrees cooler. I have an exhaust fan on top and back. But it just doesn't help. When researching, seems I am not alone with this case and a radiator.
I want a good looking case, but also want good cooling to support my new CPU i9-9900k. Opinions are welcome. Here is a picture of my setup now.
Denpepe
You can have a look at some of these and see which ones you like
