recommend generic web api monitoring app for android
Discussion in 'Webmastering & Programming' started by mord, Jun 15, 2017.
  1. mord
    mord [H]Lite
    92
    Mar 8, 2005
    My Google foo is failing me for some reason. I'm sure there are 1000 solutions for this, but dang it I can't find one.
    I am looking for an android app that can run on my phone to monitor the values in a web api response. Pull, not push. xml format.
    Ideally it would do the following:
    Consume any well formatted xml like response. I know, I know.
    Allow me to choose a field value to monitor.
    Define alert thresholds - numeric specifically.
    Define monitoring interval. I just need once per 5-10 minutes, not sub second.
    Run in the background and alert if threshold is met.
  2. modi123
    modi123 2[H]4U
    3,176
    Sep 6, 2006
    I don't know of any app that does that all in some generic fashion. You could knock a specific one out relatively easily..
  3. mord
    mord [H]Lite
    92
    Mar 8, 2005
    Yeah, that's what I'll probably do. I know it's hardly enterprise acceptable, but dang it sounds handy.
