Format _C:
- Jun 12, 2001
I have a craftsman (Sears Crapsman ) cordless drill and the battery's (It came with two) are of pretty much no use anymore because of the Nickel Cadium Memory Effect (Stupid Drill bought it in 2005 so I would think it would be new enough to use another battery type)
First of all how do I open the thing? It uses what looks like a Torx screw with a piece in the middle
here are pictures I took of the screws and battery pack
Its a 12Volt drill and I can solder ok (Not the best at it)
and once I get it open what do I do?
1. Figure out what type of battery to get
2. Figure out how they are wired (Series Or Parallel)
3. Figure out how to charge the new rebuilt pack
4. Is it worth it?
I really like the drill i have been using it as a wired drill for now (Hooked it up to the 12 Volt line on a PC Power Supply)
4. Is it worth it?
