RealTemp 3.67 for Sandy Bridge
unclewebb
RealTemp 3.67
http://www.mediafire.com/?n99nq4kn95u6i6a
-added Sandy Bridge VID / power consumption monitoring.
-added Sandy Bridge power limit adjustments if they are not locked by the bios.
-added ability to save the log file to a network computer.
-added Disable Turbo (IDA) option for Core 2 mobile CPUs.
-updated i7 Turbo GT program for Sandy Bridge CPUs.
-also updated the RTCore.dll RivaTuner plugin.
Thanks. So it now shows the Vcore real-time? That was the one piece missing before.
This is the data that RealTemp reports for Sandy Bridge now.
Unfortunately, I don't think this value represents actual core voltage. It's more like a VID voltage or the amount of voltage the CPU is requesting.
If you manually adjust the core voltage in the bios, that usually over rides the VID voltage request.
Wait,
Is this the same voltage that the CPU is trying to request, in VRM-12 spec (meaning the same voltage you would have at AUTO vcore?)
Wait,
Looks like it. Not indicative of what you might have set in bios.
