Nebell
- Jul 20, 2015
I don't know anything about water pressure inside computers.
Can I just lay my PC on the back, remove the tubes connecting PC to the GPUs and then just replace them?
Or is there going to be a whole lot of water coming out? My guess is it's going to be a lot of water since if it's going to lay on it's back, the reservoir is going to push the water out because it will be in the higher position compared to the CPU, unless, I leave the tube going from the CPU to GPU connected to the CPU and just remove it from the GPU.
Any suggestions? My 1080Ti is coming tomorrow I think and I don't have much coolant left, only about half a liter. It's not enough to fill it all but it will be enough if I leave like half coolant inside the computer.
I can order more from EKWB but it will take at least a week to arrive
Here's a photo of my system:
