Realforce rgb keyboard aeax01 replacement keys
ng4ever
I know the keyboard is discontinued but anyway to find a authentic replacement Ctrl key ? Doubt I can just buy one will have to buy a set.
Should I ask the company ?
ask realforce. looking at the product page, it does not look like it. good thing theres two ctrl keys!
also, are you talking the key or key cap? im assuming you meant the key itself as the caps are supposed to be changeable and take 3rd party ones that match the cross pattern.
so, if you want the oem. talk to them. if you dont care, get a 3rd party one.
The stock keycaps didn't look all that "amazing" to me, doubleshot abs w/ gamer font? ... sometimes you can find replacements on ebay for certain OEM keycaps.. but I didn't see anything for this one.. honestly I think if it was me, I would just start looking for a decent replacement keycap set. Unless you don't like pbt keycaps for some reason then you can look for abs sets I suppose?
https://www.amazon.com/s?k=pbt+shin...shi,electronics,144&ref=nb_sb_ss_ts-doa-p_1_7
