Commander Suzdal
- Jul 29, 2004
This is not entirely true. When you buy a CPU, you also need to buy the coresponding chipset that enables the features of that CPU. Many could argue that the chipset is even more important than the CPU itself. Every single part of a system provides important pieces to the whole puzzle. Chipset, CPU, video card, memory, etc, etc. That's why the point was made in the article to have "identical" systems. But they aren't identical, and can never be identical. Why? Because of **gasp** architectures. [H] is the one that brought up the idea of comparing the two; my point was only to level the playing field. When AMD releases a new CPU with a higher core speed than the Intel, one that would beat the X6800, will the same test be performed? No, probably not. Even if it did, I imagine there would be people in here complaining that the test was unfair due to the difference in core speed: an unfair advantage for AMD.
Again, the processor is only part of the puzzle. Look at the big picture...
It is biased when the article comes to a conclusion saying one is the winner, one that has several advantages in its favor, and people read that and make their purchases based on what they're told. They go out and spend their money on what [H] says is good, but what happens when the table is turned and AMD comes back with a winner? The two companies have started leap-frogging eachother just like ATI and nVidia. One day it's X, the next day it's Y. If the two are not compared in the same circumstances, or at least with as few variables as possible, then it would not be an even comparison. Yes, I know that people will not buy an X6800 and underclock it - I'm not a fucking idiot. If you compare an Intel system to an AMD system you are comparing more than just clock speeds. You are comparing the CPU, the chipset, memory controllers, cache, instruction sets, and so on. Do you really think that all there is to a CPU is speed? If you do, I'm sorry for you...
If all this is too hard for you to understand, I really don't know how to put it to you any easier.
The essential problem with your thought process in all of these posts is the phrase "unfair advantage." An advantage is neither fair nor unfair when comparing the best available. It is simply an advantage. If there were better components available for building the AMD system and [H] failed to use them, that would be a valid concern for the validity of the test. If so, please point them out. If you put forward your best and it isn't good enough, you lose. This is not unfair. Unfortunately, your belief that it is unfair, presumably because you don't like it, is the entire basis of your complaints.
If one team in the Superbowl has a better quarterback, should they be forced to use their backup QB in order to "level the playing field"? There is no logic to your objections. They are the equivalent of throwing a tantrum because your little league team lost a game. The market place does not care about fairness in the sense you are trying to define it. The better product wins. Too bad it wasn't on your favorite "team."
