t_ski
- Jun 13, 2006
Quote page one of the article:
We all know this to be untrue. You cannot have two CPU's from different manufacturers run on the same chipset. To all of us hardware enthusiasts that is obvious. You can't call them identical if they aren't. Simple fact.
Then from page two:
Not only are they different chipsets, but the motherboards are also from different manufacturers. We all have seen countless reviews where one brand of motherboard was pitted against another brand of motherboard, both with the same chiset, feature set, etc., and one outperformed the other. You can't say that identical in any way. Then, as brought up earlier in this thread, [H] went as far as to enable Linkboost, which is a feature found on only one of those boards. More apples to oranges.
I never suggested that they should manipulate the cache. Neither of these CPU's allow that. I only suggested that the clock the CPU's to the same speed, in that they could eliminate as many variables as possible. If these CPU's have the ability to change the multiplier then it would be simple to do a set of benchmarks at various speeds seeing what CPU MHz really has an effect on in gaming.
This test is like pitting two different dogs against each other in a race and seeing who can run faster, but giving one of the dogs a shot of speed before the race. One went faster cause it was given an advantage over the other. There is no control variable. It's all apples to oranges. You want it to be a fair test, then level the playing field.
The systems are identical with our CPUs being isolated to see if one or the other gives a better gaming experience.
Then from page two:
For our Intel Core 2 Duo X6800 (2.93 GHz) CPU we are using the EVGA nForce 680i SLI motherboard with the latest P24 BIOS and NVIDIA 9.53 nForce chipset drivers. The BIOS was configured with default CPU frequencies and default memory frequencies at the fastest timings, LinkBoost was also enabled.
For the AMD Athlon 64 FX-62 (2.8 GHz) CPU we are using the ASUS M2N32-SLI Deluxe 590 SLI motherboard. The latest BIOS, 0706, was used as well as the latest nForce chipset drivers 9.35. The BIOS was also configured at default CPU frequencies and memory frequency with the same memory timings.
If performance is achieved with cache, clock speeds, front side bus or anything else, great! Performance is performance irregardless of other factors. Cache is not a user device. You cannot interact with it directly from the user level, so its only purpose is to increase performance of the CPU. That's it.
Now, if the cache afforded you different opportunities, if you could interact with it in a real way, and if it were truly relevant, this would be a different story.
