Ready to move on from Noctua fans, looking for black/white fans for slim radiators
Discussion in 'Overclocking & Cooling' started by doug_7506, Jun 29, 2018.
  1. doug_7506
    doug_7506 2[H]4U
    3,207
    Oct 17, 2004
    In the process of piecing together a new build using the TT View 71. While I had a great run with my Noctua fans, I am ready to move on to something that is a little more aesthetically pleasing.
    I have Alphacool NexXxoS ST30 280mm & 360mm radiators. These are slim radiators. So I am looking for some fans in either black or white to pair with them. Don't need LED's but if they have them, they can't be obnoxious.
    Appreciate everyone's input!
  2. Araxie
    Araxie [H]ardness Supreme
    6,344
    Feb 11, 2013
    Corsair ML series are great.. also check for the newer noctua black fans
  3. doug_7506
    doug_7506 2[H]4U
    3,207
    Oct 17, 2004
  4. DTN107
    DTN107 [H]ardness Supreme
    4,679
    Jun 30, 2008
  5. cyberguyz
    cyberguyz Gawd
    713
    Aug 28, 2014
    For corsair's offerings I prefer the Corsair SP fans
    Specs for MLs :
    Specs for SPs
    While the ML series are quiet, the SP series are designed for radiator use with higher static pressure (SP :) ) and a higher top speed to cram more air thru a radiator when needed. When the speed is not needed, they can be dialed back to be every bit as quiet as the MLs.
    Now for the "I don't care about noise" crowd there are the high speed 38mm thick Delta AFB1212GHE and panaflow NMBs which are hella powerful and loud. Just never, ever plug those into a motherboard header!!!
    SticKx911 and doug_7506 like this.
  6. doug_7506
    doug_7506 2[H]4U
    3,207
    Oct 17, 2004
    Nearly double. Impressive. I just like to be able to set my fancurve and then forget it. Without PWM can you do that? Do newer motherboads allow for voltage control direct on the motherboard.
    It's very important to me because this computer will be about 2 feet from my head.
  7. cyberguyz
    cyberguyz Gawd
    713
    Aug 28, 2014
    Yeah they can handle that via voltage variation. At least the boards I used those fans on did (used them with a Corsair i115h AIO cooler). If your motherboard doesn't Speedfan should work for you.
  8. doug_7506
    doug_7506 2[H]4U
    3,207
    Oct 17, 2004
    Going to be using an aorus gaming 7 z370 board. Might have to order a sp120 and see how it works with the board and then go from there. Looks like it will work better and be cheaper.
  9. DedEmbryonicCe11
    DedEmbryonicCe11 [H]ard|Gawd
    1,555
    Jun 6, 2006
    Some cheap motherboards used to fake PWM with voltage control and thus damage real PWM fans over time. It's okay to use a 3 pin fan in a 4 pin header and use voltage control (if available) but just don't ever use a PWM fan that way.
  10. pendragon1
    pendragon1 [H]ardForum Junkie
    11,185
    Oct 7, 2000
    take a look at the cm jetflows too. they are ~95cfm and 2.7pressure vs the sp120s ~65 and 3.1.
  11. Guarana [BAWLS]
    Guarana [BAWLS] I am THAT Stupid
    1,756
    Oct 3, 2001
    Over 27mm H2O Pressure on the Delta? GOD DAMN!
    Of course, as a Delta, I might have to put the case in the neighbor's basement.
    cyberguyz likes this.
  12. cyberguyz
    cyberguyz Gawd
    713
    Aug 28, 2014
    Yeah those are some of the hairiest 120mm fans on the market. And they get LOUD!!! You would definitely hear them screaming from the street outside your house. They have another model that puts out 252cfm and 36mm H2O pressure. @65db you might want to invest in some really good earplugs.
    doug_7506 likes this.
  13. DedEmbryonicCe11
    1,555
    Jun 6, 2006
    I have one of the ~2500 RPM, 103.8 CFM Panaflo 120x38mm fans and that thing can jump around on the desk if it's not secured at 12v. I haven't used it for anything in a long time but I keep it around just in case it becomes useful for a crazy project.
  14. -PK-
    -PK- [H]ard|Gawd
    1,800
    Aug 6, 2004
    Phanteks F120XP would be very similar to the Noctuas if you're looking for silent fans. They also make a MP 7 blade version for radiators with a denser fins per inch, but they are buzzy compared to the XP. Then they have a SP version that uses voltage regulation instead of PWM. Since your radiator's FPI isn't that dense, you could focus on the cfm; higher static pressure fans might add some unnecessary turbulence noise.
  15. {NG}Fidel
    {NG}Fidel [H]ardness Supreme
    5,836
    Jan 17, 2005
    Personally loving the MLs from Corsair. But I will be honest that beyond these, Noctuas, and cheap shit fans. I dont have much experience in fans.
  16. doug_7506
    doug_7506 2[H]4U
    3,207
    Oct 17, 2004
    Lots of lots of great tips.
    After doing some more research, it think the SPs are a no go. Doesn’t look like the brightness can be dimmed. These are
    Going to be about three feet from my monitor so I need to be able to turn down the brightness.
    Brings me back to the MLs. They seem to be the highest rated fans that check all the boxes. PWM, leds, adjustable brightness, and decent static pressure.
    Amazon has 20% off with Amex points, so I’ll probabky be using that to order me some tonight.
