Raytracing and Mesh Shader Tests...
JCNiest5
For some reason, I'm unable to test these two benchmarks in 3DMark.
This is for my brand new EVGA RTX 3090 FTW3 Ultra...
For Raytracing, it says:
! Your PC is unable to run this test
You need Windows 10, 64-bit with the May 2020 Update (version 2004) to run this test.
You need a graphics card with drivers that support DirectX Raytracing Tier 1.1 to run this test.
For Mesh Shader, it says:
You need a graphics card with drivers that support mesh shaders to run this test.
Some posts on the web say to uninstall the current video card driver and reinstall the latest one. Done that. I'm on the latest Windows (64-bit) update as well. Still no go.
Any ideas?
Armenius
Exactly what version of Windows 10 are you running? Press the Windows key in the taskbar, type winver and run that. Take a screenshot of the window that pops up and post it here.
JCNiest5
No screenshot, but it says Version 1909 (OS Build 18363.1440)
Armenius
You need to update your version of Windows. If you were on 2004 it would say "Version 2004 (19041.207)." The WDM and DirectX version included in 1909 does not support ray tracing or mesh shading.
JCNiest5
Oh...I thought the updates do that for all updates. Will update.
JCNiest5
One time after an update, my PC acted really weird, like someone was controlling my PC. Upon launching a web browser, weird characters would be typed on my URL line automatically. I got completely freaked out I thought someone had gotten a control of my PC. I reset my PC and did a Restore or Uninstall of Windows to get everything to work again. I got scared so now I usually don't allow Windows to do updates anymore.
GoldenTiger
You had a virus. Windows updates don't cause that.
