MrGuvernment
- Aug 3, 2004
nilepez said:Imaging is fine if you're doing you're reinstalling a lot, but otherwise, wouldn't it be better to slipstream XP with all the patches up to now and maybe even add the latest patches for your MB and Video card?
prtition size will not affect performance.
and the idea of a ghost image is to get your system with all your installed software back up and ruing in 1/4 the time it takes to format / update - reinsrtall all your programs you use and such.
Once the image is done, go install newer updates - it will still be ALOT faster then a fresh format.
