It was time for some updating. My old system, though still running strong, was starting to show its age. Dual core black edition kuma 7750, 6gb ddr2 memory, origional 30gb OCZ vertex 30gb SSD and a 150gb raptor, 2TB storage array. Will make a good file server! haha
So just got the new build together over the weekend. The primary goal with this build was just to get something that would give me an upgrade path through individual components without having to buy all new hardware all at once, again. I know I could have waited for bulldozer but the new board is AM3+, and supposedly supports bulldozer with a BIOS upgrade. Though I know I wont be taking advantage of all of the features of bulldozer right away, this should at least give me the option to upgrade in peices. This machine is mainly used for development, running several VMs simultaneously, and the occasional gaming.
Motherboard: MSI 890FXA-GD65
CPU: AMD Phenom II X6 1055T
Memory: CORSAIR Vengeance 16GB (4 x 4GB) DDR3 1600
Video Card: MSI R6950 Twin Frozr III PE/OC Radeon HD 6950 2GB
OS Drive: OCZ Vertex 3 120GB SATA III MLC SSD
Program Drive: Momentus XT Solid State Hybrid Drive
Power Supply: XFX Core Edition PRO750W
Monitors: Still using dual 19's @ 1440x900 for the moment, might see some dual 23's in the not so distant future.
Only one thing I regret in hindsight, I should have opted for the MAXIOPS version of the SSD. But honestly Im not THAT much of a perfromance nut that I would notice. Also, yes I know the the momentus xt is a laptop drive, I just wanted to try out the hybrid SSD thing and this seemed to be the only option. Might swap this out for something else and toss this in my laptop if you all think it would be that much of a performace difference. This is primarily just a "Program Files" drive, so I figured I might see some benefit from the SSD storage here.
Anyhow I just wanted to hear what you all think. I know there are plenty of faster (and much more expensive options) but I have already used up my budget for this build. With that in mind, I'm still inside the return window for all of this stuff so if you have any suggestions that are truly worth replacing, without adding extra cost, I would very much appreciate your input.
