DermicSavage
- Jun 8, 2004
[H] I need your opinions on this build.
I currently have an old laptop with a 2TB external hard drive acting a dedicated XBMC/NAS box (it is always connected to my TV). I am hitting the 2TB capacity pretty easy on this little hard drive, and I'm getting rather frustrated with the USB transfer rates (I max out at about 40MB/s), so an upgrade is on the table for consideration.
Here is what I intend to use the system for:
-Run XBMC, Netflix, uTorrent, Crashplan (I intend to be a backup server for family), Tversity, and my OpenVPN server
-Will use either Windows 7 or Windows Small Business Server (I have a student license for both). I very much lack proficency and interest in Linux.
-I intend to use either SnapRAID or FlexRAID for snapshot RAID. I do not need any highpower RAID at this time, just some weekly snapshots.
-I will not be recording or ripping any DVDs or BRs
-I want to have the option to upgrade with a CableCARD in the future, and I'm not sure how much power I will need for that, but this is optional.
-This box will run 24x7 and should rarely ever be shut down or rebooted
-I want to keep the cost around $800 with a max of $900
I have been parting together stuff on Newegg and have two possible builds in mind, Intel & AMD:
(Apologies for the newegg links)
Common Parts:
Case: nMEDIAPC HTPC 5000S $60 (This case will sit in my home theater shelf and cannot be taller than 5.8")
Power Supply: CORSAIR CX430 430W $40
Memory: G.SKILL Ripjaws X 4GB (2 x 2GB) DDR3 1333 $36
SSD: Crucial M4 CT064M4SSD1 64GB $80
Storange: 3xWD Red WD30EFRX 3TB $151
Intel:
CPU: Intel Celeron G1610 Ivy Bridge 2.6GHz $50
Motherboard: ASUS P8H77-M LE Intel H77 $75
or
AMD:
CPU: AMD A4-5300 Trinity 3.4GHz (3.6GHz Turbo) Socket FM2 $55
Motherboard: MSI FM2-A75MA-E35 FM2 AMD A75 $60
All in all both builds are about the same price around $800.
Would there be a significant difference in the performance using the AMD processor over the Intel Celeron? For the most part, I would think that only the GPU power would be the determining factor here, but I'm not sure how relevant that even is. If I used a Ceton or HD Homerun later on would I need that extra power for any transcoding?
Am I overlooking anything with this plan to have a dedicated home server/HTPC?
Thank you for the input [H]
Common Parts:
Intel:
or
AMD:
