Ram Upgrade - Advice Needed
Discussion in 'Memory' started by Cacophony05, Jun 13, 2018.
  1. Cacophony05
    Cacophony05 n00bie
    11
    Aug 20, 2012
    My system is getting a little old (built in 2012) and I'm looking at upgrades. The system specs are:
    Intel Core i5 3570K
    Asus P8Z77-V LK Motherboard
    G.Skill Ripjaws Series F3-12800CL9D-8GBRL 2 x 4GB DDR3 1600 RAM
    eVGA 02G-P4-2670-KR GeForce GTX 670 2GB PCI-E Video Card
    I'm looking to upgrade my GTX 670 to a 1060 6GB or RX 580, but I was thinking about adding a little more memory (from 8GB to 16GB) at the same time.
    Would it be best to add another 2x4 kit or replace the current kit with a 2x8? Are the potential compatibility issues? And is this even a good idea?
    I'd like to stretch this rig out for another couple years if possible, so I thought adding a little more RAM might help with gaming (PUBG generally).
    I'd appreciate any advice, and specific examples would be extremely useful.
  2. horrorshow
    horrorshow [H]ardness Supreme
    5,659
    Dec 14, 2007
  3. HiryuuX
    HiryuuX Limp Gawd
    208
    Jul 16, 2017
    RAM upgrade wouldn't be a bad idea. I'd probably just buy a working used kit though, can get another 8GB for around $35-40 ish.
  4. Ruiner
    Ruiner 2[H]4U
    3,002
    Aug 22, 2000
    FWIW, PUBG likes high clocked ram. If you can find something that will run at 2133 or better at decent timings, grab it.
  5. Archaea
    Archaea [H]ardForum Junkie
    8,729
    Oct 19, 2004
    You don’t generally need more than 8gb of RAM for gaming yet.
    3:05
    Frametimes can be improved by a smidge and minimum frame rates can maybe be improved by a smidge (maybe 10% on some titles), but averages and maximum FPS will largely stay the same between 8 and 16GB.
