Ram speed or timming?
Discussion in 'Memory' started by beheo2019, Oct 30, 2019.
  1. beheo2019
    beheo2019 n00b
    35
    Aug 31, 2019
    I got a gskill tridentz 3200mhz cl14, but bought another kit hyperx predator 4000mhz cl19. Which one is better? The Hyper X is $50 cheaper.
  2. hititnquitit
    hititnquitit Gawd
    535
    Apr 16, 2018
    They both use the same b die ics and should run the same speeds and oc equally. The gskill have a lower stock xmp. While the hyperx have two xmp profiles, one is 3600 and the other is 4000.
    Personally i would go with the hyperx but im biased. I have 2 sets.
  3. pendragon1
    pendragon1 [H]ardForum Junkie
    14,334
    Oct 7, 2000
    if the chips are the same as he says^^ then i'd meet in the middle at 3600 or 3733 to get a balance of mhz vs cas
  4. dasa
    dasa Limp Gawd
    344
    Feb 19, 2012
    I am running 4x8GB 3200c14 B die at 3600c15 as my CPU memory controller doesn't like going higher.
    But if you want to take the time to OC those kits will probably do 4000c17 with ~1.45v if the memory controller can handle it.
  5. amittalkin
    amittalkin [H]Lite
    115
    Jun 19, 2015
    I dont think hyperX is b-die. that timing cant be of b-die.
  6. hititnquitit
    hititnquitit Gawd
    535
    Apr 16, 2018
    go to ocf and check out Woomaks review of the hyperx 4000s.
  7. kirbyrj
    kirbyrj [H]ard as it Gets
    24,717
    Feb 1, 2005
    I don't know as I don't have the sticks in front of me, but 4000Mhz Cas 19 is a popular Micron E-die speed/timing combo.
  8. hititnquitit
    hititnquitit Gawd
    535
    Apr 16, 2018
    Its hard to believe but hynix has ics that will do ddr4 4000+ now. With very b die like timings(they are cheap to boot, $90 2x8). Woomak just did a review on the new hynix ics and they are incredible ocers. If i remember correctly its the v power brand or something color...i forget. One of the new brands. Ill link the review when im off my phone.
    Anyhow the hyperx 4000s are b die but i dont know what the lower speeds are. There are definitely alternatives to b die now vs a year or 2 ago.
  9. kirbyrj
    24,717
    Feb 1, 2005
    I saw a different review of the 3200Mhz RAM and it was Hynix. I don't buy into the B-die hype anymore, especially with Hynix prices so cheap comparatively. I got 2x16GB 3600Mhz running Cas 16 at $130. Much higher than 3600Mhz and you lose the 1:1 ratio with the infinity fabric with a Ryzen setup. I just don't see the value of a $200+ kit of memory right now.
  10. Comixbooks
    Comixbooks Ignore Me
    13,929
    Jun 7, 2008
    The one that doesn't crash the system =)
    I just upgraded from 2400hz to 3200hz crucial ballistic the older version.
    I saw like no improvements for most games my Win OS is faster I can tell FPS wise a few were like 2 frames higher but some were lower. If you want to upgrade to that 4000hz Ram it's probably the only way your going to see real improvements . Then again I was just running in game Benchmarks and not playing the actually game where you might actually see more of an improvement.
  11. beheo2019
    beheo2019 n00b
    35
    Aug 31, 2019
    I got 3200mhz cl14 and returns it. Now running 4000mhz cl19 and dont see anything.
  12. Comixbooks
    13,929
    Jun 7, 2008
    You wouldn't notice it but it does exist.
  13. hititnquitit
    hititnquitit Gawd
    535
    Apr 16, 2018
  14. Comixbooks
    13,929
    Jun 7, 2008
    I ran all the benchmarks yesterday again in game benchmarks and got like 2-3 FPS gains in like every test but at least my system is really snappy anyway.
  15. hititnquitit
    hititnquitit Gawd
    535
    Apr 16, 2018
    Yeah high speed memory is mostly for tweaking and seeing what kind of crazy high ocs you can hit or super tight timings. Other than that and benching its definitely a want vs a need. As easy as cpu and gpu ocing has become i get more entertainment out of memory ocing now.
  16. dasa
    dasa Limp Gawd
    344
    Feb 19, 2012
    You will be GPU limited in average FPS and faster RAM only helps the CPU so gains will be much larger in CPU limited sections of gameplay.
    These days you can get more performance out of overclocking RAM than overclocking the CPU and you don't have to spend a heap on extra cooling and power to do it just the time and patience.
    Comixbooks likes this.
