Vlad_13
- Jun 22, 2006
I keep getting BSODs with "page_fault_in_non_paged_area" message. Here is my original thread. When i run MemTest, 7 passes i get no errors. Can memory "malfunction" or "crap out" when its under stress and heat? Yes it is OCed to 499 MHz with 0.5v bump, 5-5-5-18.
I have a nice ventilated case V1000Z, but it is kinda cramped in there... but i do have a Delta fan in there AFB1212VHE which can push 129CFM at 3200RPM...
When i leave the main fan on 8v ~ 2220RPM i get the BSODs from time to time on demanding games like L4D and Crysis, but when i crank up the fan to 3000RPM system looks stable, no BSODs... CPU btw and the GPU are all in the safe limits (CPU around 41-46C and GPU around 65-70C)
I know the RAM gets hot in general but when its in extremes it fails? So by increasing the air flow in the system it helps the RAM? Can some one confirm?
