RAM for TR 2950X
Discussion in 'AMD Processors' started by compgeek89, Jun 12, 2019.
  1. compgeek89
    compgeek89 Limp Gawd
    141
    Nov 30, 2018
    Hey all,
    I am building a media workstation for a friend based on a 2950X and an ASUS X399 Aorus Xtreme. I am looking to go with either 4x or 8x 16GB (64GB or 128GB). Haven't 100% decided. That's where my questions come in:
    - Is there a relevant performance degradation w/8 sticks?
    - I know the Samsung B Die preference, but I also don't want to spend an arm and a leg. What are some ideal kits for this setup? (Links appreciated!)
    - Is 3200/C16 a reasonable target? Any reason to aim higher? Or maybe it's OK to aim lower and save the dough? 3200/C14 or 3333+ might be nice, but it's not worth 50%+ more $$$... is it?
    Any other advice/insight ... feel free!
  2. Algrim
    Algrim [H]ard|Gawd
    1,429
    Jun 1, 2016
    Media workstation; would this be Adobe workflow or some other editing/production station?
    My 12c/24t machine with Adobe workflow sometimes gets close to hitting all 64 GB of installed memory but I wouldn't build out a machine with 128 GB just for those one or two occasions when it's close.
    Just my 0.02 USD or so...
  3. compgeek89
    141
    Nov 30, 2018
    Adobe Effects, Premier Pro, maybe some other products. I'd like it to be sufficient for a while, not just the next couple years.
  4. Algrim
    Algrim [H]ard|Gawd
    1,429
    Jun 1, 2016
    If this is for paid projects get the 128 GB and relax knowing you're relatively future proof (and you'll make up the cost difference eventually). If this is for a hobby call it a day at 64 GB.
  5. compgeek89
    141
    Nov 30, 2018
    What if it's for a non-profit ... haha
  6. Algrim
    Algrim [H]ard|Gawd
    1,429
    Jun 1, 2016
    Depends on whether or not you're getting into 4K footage for which I'd go with 128 GB despite the cost. Needing to upgrade RAM later would mean ditching the entire RAM investment. If you're trying to keep costs down that's not going to help.
    compgeek89 likes this.
  7. compgeek89
    141
    Nov 30, 2018
    Definitely will involve 4k, so it sounds like I should do 128GB.
    Still open to suggestions on the speed/latency/model selection
  8. mda
    mda [H]ard|Gawd
    1,557
    Mar 23, 2011
    You can probably (but not guaranteed) run 2 DIMMs/Channel at 3000/3200 with the later BIOS revisions.
    I'm doing 4x16GB 3200 C16 Corsair LPXs with a 2700X, non BDIE RAM.
    Worst case is you could probably run 2666/2800...
  9. Boil
    Boil [H]ard|Gawd
    1,375
    Sep 19, 2015
    Go for a G.Skill kit, 3200MT/s CAS 14 Samsung B-die seems to be the current sweet spot...
    14-14-14-34 timing is what you are looking for...
    128GB kit on NewEgg...
  10. compgeek89
    141
    Nov 30, 2018
    Yea, ideally... But that's more than 2x the price of C16. I can't see how it could possibly be worth that much more.
  11. Boil
    Boil [H]ard|Gawd
    1,375
    Sep 19, 2015
    I believe the speed of the Infinity Fabric set by memory speed / timing...?
  12. Alienslare
    Alienslare Limp Gawd
    141
    Jan 23, 2016
    I have a mutual friend who told me once that going above 3200mhz on Threadripper is not so stable if you have to have 64gb ram.
