Rails for Norco RPC-4020
DangerIsGo
Hi all,
I have a V1 Norco 4020 4U NAS case. This isn't the one that's currently on Norco's site as that is V2. It's this one:
https://gyazo.com/e7bc62b2dafb0fc62d6d1b70700d7fe1
There was a post I found here where these were recommended but my OCD doesn't like that. I'd prefer actual rails for it and was wondering what I should do.
Do the norco RL-26 or RL-20 rails work sufficient enough?
It's been over 5 years since that was asked and many things have changed since then.
Do I have better options if I were to upgrade my case to the updated 4020, or a newer model such as the 4220 or the 4224 or would I still be in the same boat?
EDIT: I just looked at the side holes for the 3 new cases (4224, 4220, and new 4020) and they are all identical.
EDIT2: I just compared my side holes to the new hole format and they seem to be radically different.
https://gyazo.com/edefc851b8c565e533bc3601e9f3902d (Mine)
vs
https://gyazo.com/cdd2342a23e620b3ec1900964112a772 (Current)
xx0m3gaxx
could you give a pic behind the handle of your case? it should have a small notch in it, if so 99% of the rail kits from norco will work so long as they meet weight requirements.
http://prntscr.com/8obhmq
that is the only holes that matter for the rail kits from what I have seen, been using norco for a while now and the rails seem to be great quality ( bought them from newegg) they come with all the hardware needed and adjustable depth for racks
AcidBurn
RL-26
I have the old style case and the RL-26 worked fine in my rack.
DangerIsGo
I do not have the notch xx0m3gaxx. It's the first gen.
I ended up getting the RL-20 rails as that's what another guy I saw had on that same exact case. I'll see how it works and report back tonight.
DangerIsGo
RL-20 rails fit perfectly. I think I just answered my own question. Now to see how it works on the rack (The rack system is in pieces right now for a new paint job and cleaning).
