Hi, I've got a GPU requiring two 8-pin connectors for power.
My PSU, Corsair HX620, has two 6-pin outs and a bunch of molex/sata outs. It's modular, and within the specs required for this card.
The GPU came with two Y connectors that each convert two 6-pin PCI-E into 1 8-pin PCI-E.
The internal board for the modular plugs is shown here: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story2&reid=21
Basically, one PCI-6 out is on Rail1, the other PCI-6 out is on Rail2. There are modular/MOLEX outs on Rail1 and some on Rail2.
If I hook up a cable with two molex outs to each rail, I'll have 2 molex on rail 1, 2 on rail 2.
Is there an optimal/safe way to hook this up to my PSU? I have Y-cables that can convert 2 molex into one PCI-6.
My current option I am considering is each PCI-8 connector comes from one rail: One comes from Rail1 PCI-6 + 2 Rail1 Molex. The Y-cable for the molex is plugged into two molex outs from the same cable. The other PCI-8 is all on Rail2.
Another option is something more balanced. Maybe the Molex to PCI-6 cables each plug into both rails (the Y-Cable plugs into two different Molex cables). Then they are each paired with a PCI-6 to make a PCI-8.
The last option is both PCI-6 into one PCI-8, and both Molex->PCI-6 adapters into one PCI-8.
Thanks for any help.
