Hello all,
I have an LSI MegaRAID 9261-8i and I just added the 8th HDD to it.
Before continuing I will put the numbers of previous expands.
I had 4x 3TB HDDs in RAID5, expanding to 5 HDDs the operation took me around 4 days.
Then expanding to 6 HDDs it took me also around 4 days, then expanding to 7 disks and changing to RAID6 it took me around 5-6 days.
All of this was on my main rig which had an i7-3930k and 16GB of RAM.
Having 7 HDDs on my main rig was making it difficult for me to do some stuff so I decided to move everything related to the HDDs to a new rig and make it a NAS box. (I was only temporarily moving it to a new box because I'm planning to get a dedicated server (twin xeon) so I went cheap with the temp NAS box).
I got an intel pentium G2020 (2 cores) and 4GB of RAM, 450W and installed the RAID card to it and put all 7 HDDs to it. (it worked fine, I can stream without any problems, even with 5 people streaming at the same time). Anyways my 7 HDDs got filled up and I wanted to expand. So I got the 8th HDD and did the expand which I did like 3 times already before.
I got an estimated time of around 120 hours. The first couple of days it reached 15%, (which is around 7% per day), this isn't really bad, however on the 3rd day it only increased to 16%, and the next day 17%, it seems that it got to only 1% per day.
I started the reconstruction process on the 5th of June and it only reached 29% now (thats 15 days!)...
I'm sure this isn't normal, but what might be the cause? from my understanding, when reconstructing, the raid card uses its onboard cpu to do the operation? or does it use the PC CPU?
Another thing, is the 450W power source causing this problem?, lastly, since this was a new setup I didn't configure window's updates, so the system got booted a couple of times in the middle of the operation. (I booted a lot in my old rig and it didn't cause a delay).
At this rate it will take over a month to expand successfully (if no other drive fails because of the expanding)... Any suggestion guys?
