I currently use Windows a lot, but I'm slowly moving towards open source oses as I am a programmer.
I'm wonder if I set up my OS on a small HD and then slowly add more hds after my initial bild, will I be able to set up raid on it after the fact or does the Raid need to be set up with the OS?
Also, do I have to do Raid separately for both OSes or is there some way I can have the drives/paritions with my OSes in one place and then separate drives dedicated specifically to RAID on their own regardless of OS?
I guess it would be kind of hard because windows can't read the format Linux uses, but if I set up raid for the windows system will I be able to work it in any way that the linux boot still experiences a speed or redundancy benefit?
Thanks.
Thanks.
