- May 18, 1997
It took us a bit longer to get it done this time around, but as always, a full review with nothing but real gameplay data for you to base your opinions on. AMD Radeon VII Video Card Review.
Radeon VII with 8GB at a cheaper price would be sticking nails into nvidia's butt.
All hail new cards to bring older card prices down though!
/RX480 still
Hard to say. It would have half the memory bandwidth and with Vega heavily relying on memory bandwidth I question how well an 8GB VII would do.
She does mid 89 in ETH vs 44 on V64, V56 with the same power draw of 160 Watts...
On a more important note: hands off me power grid!miners should be shot confirmed dead then shot again hands off me gpus
So how is it getting almost double the mine performance? Should have been more like 30% at most? You make it sound like crypto could take off again from a power usageShe does mid 89 in ETH vs 44 on V64, V56 with the same power draw of 160 Watts...
Thank you, as always great review. RE2 justifies the 16 Gb of VRAM.
Not really. Allocating the memory isn't the same as actually needing it, or even using it. You could probably put a 24GB card in there and it would just allocate the whole thing...
It needs to have 16 Gb to utilize 4096 bit memory pipe. Had it been released by nvidia it would not be an issue. Had it come out with 8Gb you would be bitching that it is not enough. Lets just stop right here.
It's a decent card...if it was $599.
From a gaming perspective, I wouldn't pay the current $699 asking price or even the $649 mentioned in the review. If you do a decent amount of productivity work that would require a GPU like this then the value proposition for you may be more appealing. Overall, the enthusiast GPUs from both AMD and Nvidia this generation are overpriced.
HBM 2 has 2GB,4GB and 8GB stacks that are pin compatible. So with the same interface/bandwidth you could have 8GB, 16GB, or 32GB cards.
Right now this is essentially just a rushed, rebranded Radeon Instinct card, but if no other AMD next gen part shows up soon, I expect AMD will eventually have cheaper 8GB Vega 7 cards using 2GB HBM stacks.
I think 2 production lines could offset the savings of having 3 stacks instead of 4. Apparently Vega VII is quite expensive to build. AMD may not afford having a cheaper model.You forgot using 3 stacks instead of 4. Wouldnt be 4096bit but could be doable unless there is a hardware issue in vega against it.
I didn't forget. Just addressing the claim that it "needed" 16GB to get the full interface.
You could actually store the entire game on 24GB vram. Ain't RE2 total size like 22GB? I agree people go retarded over ram usage.Not really. Allocating the memory isn't the same as actually needing it, or even using it. You could probably put a 24GB card in there and it would just allocate the whole thing...
