Radeon VII - PowerColor or Sapphire?
Discussion in 'AMD Flavor' started by McClintoc, Apr 9, 2019.
  1. McClintoc
    McClintoc [H]ardForum Junkie
    16,108
    Sep 27, 2005
    I just got a $100 Amazon gift card and have been wanting a Radeon VII but didn't particularly like the $699 price tag. With the gift card I only pay $599 out of pocket so I am going to pull the trigger. The catch is, it has to come from Amazon. I really want the MSI card since my mobo is MSI but on Amazon it's $769. My only $699 choices on Amazon are PowerColor or Sapphire. I've owned quite a few Sapphire cards in the past so I am leaning towards that one. Should I go with it or is there any good reason to get the PowerColor?
  2. Rvenger
    Rvenger [H]ard|Gawd
    1,651
    Sep 12, 2012
    Only warranty support. All the cards are the same.
    SeymourGore likes this.
  3. cybereality
    cybereality [H]ardness Supreme
    4,385
    Mar 22, 2008
    I would get Sapphire.
  4. McClintoc
    16,108
    Sep 27, 2005
    I pretty much had my mind made up when I made this thread. I did go ahead and get the Saapphire.
    Josephrr likes this.
  5. cybereality
    4,385
    Mar 22, 2008
    Right.
    PowerColor is okay. I mean they are mostly just the same card anyhow.
    But I had a lot of trouble selling a used PowerColor Vega 64. Resale value was not good.
  6. kirbyrj
    kirbyrj [H]ard as it Gets
    24,218
    Feb 1, 2005
    If that's the case, run from Sapphire. I RMA'd a bad 7950 and got 3 bad cards back from them.
    Rvenger likes this.
  7. Rvenger
    Rvenger [H]ard|Gawd
    1,651
    Sep 12, 2012
    I did have a good experience with Powercolor in 2015.
    kirbyrj likes this.
  8. McClintoc
    16,108
    Sep 27, 2005
    This will be my sixth Sapphire card out of 15 total cards owned over the years. I've never had a problem with them. But that just means I've never had to deal with their warranty service.
    kirbyrj likes this.
  9. Rvenger
    Rvenger [H]ard|Gawd
    1,651
    Sep 12, 2012
    Honestly, those cards are built solid. I haven't seen any serious defects except for some having a fan rattling issue here on the forum. I wouldn't worry about it.
  10. Archaea
    Archaea [H]ardForum Junkie
    9,181
    Oct 19, 2004
    Sapphire is perhaps the most reputable of the AMD parnters. That choice would be easy for me.
    Powercolor packed their 580 and Vega cards with nothing but cardboard. Sapphire at least used foam! My Powercolor RMA experience was abysmal, but I’ve never had to RMA a Sapphire.
  11. RAutrey
    RAutrey [H]ard|Gawd
    1,605
    Jul 25, 2002
    Yep. I went from a MSI Vega 56 to a Powercolor 64 and the difference in overall quality of the packaging and card aesthetics was significant.
  12. SpongeBob
    SpongeBob The Contraceptive Under the Sea
    648
    Jan 15, 2011
    I had issues with a powercolor card. Performance was lacking. They had promoted some overclocking software at the time (their own). I asked them about it and the told me overclocking voids the warranty. Go Sap.
  13. cybereality
    4,385
    Mar 22, 2008
    AMD does the same thing. Even though their drivers include overclocking software, it voids the warranty if you use it. Go figure.
  14. sirmonkey1985
    sirmonkey1985 [H]ard|DCer of the Month - July 2010
    21,248
    Sep 13, 2008
    it's more of a protection clause due to people abusing warranties back in the day when there were no baked in protections. basically as long as the reason the card is being RMA'd doesn't have anything to do with overclocking or using a modified bios that bypasses the built in limitations then you're fine.
  15. evolucion8
    evolucion8 Gawd
    914
    Mar 15, 2006
    Its a matter of warranty more than anything, as all Radeon VII are reference designs purchased directly from AMD by OEMs, they just slap their sticker and move along.
  16. FlawleZ
    FlawleZ Gawd
    790
    Oct 20, 2010
    It would be truly epic if an AIB like Sapphire produced a custom Radeon VII. One can hope...
  17. harmattan
    harmattan [H]ardness Supreme
    4,214
    Feb 11, 2008
    I'd also vote Powercolor. I had an excellent RMA experience on a card a few years back. The rep was greaf, got a new card super quick.
