Radeon VII or an Nvidia 2080 in SLI or Nvidia 2080 ti single card?
Discussion in 'Video Cards' started by The Cobra, Feb 4, 2019.
  1. The Cobra
    The Cobra 2[H]4U
    2,589
    Jun 19, 2003
    Hi All,
    Gonna be making a purchase soon on the above cards:
    Radeon VII in mGPU (Crossfire, if it is supported)
    Nvidia 2080 in SLI (EVGA)
    Nvidia 2080 ti (Single Card for now)
    Opinions?
  2. dvsman
    dvsman 2[H]4U
    2,496
    Dec 2, 2009
    Mostly gaming? 2080ti single card all day long.
    SLI / XFire support is just too flakey.
    NukeDukem and legcramp like this.
  3. Boil
    Boil [H]ard|Gawd
    1,229
    Sep 19, 2015
    Seeing as your sig rig is all-AMD, I would go for the Radeon VII...
    Dunno about the Crossfire...
  4. Maddness
    Maddness [H]ard|Gawd
    1,163
    Oct 24, 2014
    According to techradar no crossfire at this stage for the Radeon 7
    I'd wait until the 7th, it's only a few days away and see reviews before making up your mind. It's what i'm going to do.
  5. FrgMstr
    FrgMstr Just Plain Mean Staff Member
    48,436
    May 18, 1997
    Link?
  6. Chimpee
    Chimpee [H]ard|Gawd
    1,347
    Jul 6, 2015
  7. Maddness
    1,163
    Oct 24, 2014
    Yeah that is what i had read. It looks like 3rd party info. My apologies for saying it was from AMD. Maybe Kyle, you could reach out to AMD for an update.
    Once again my apologies for saying that the Radeon 7 doesn't officially support Crossfire.
  8. The Cobra
    The Cobra 2[H]4U
    2,589
    Jun 19, 2003
    I to saw the techradar article a few days back. I will take the "no crossfire support " with a big pile of salt. In my mind, I can't see AMD just cutting off crossfire support for games that still take advantage of two GPUs. I know they dropped the "Crossfire" brand a few years back (https://www.pcworld.com/article/322...brand-as-multi-gpu-gets-more-complicated.html) but they still supprt multi-gpu in their drivers.
    I'll know on the 7th...
  9. exlink
    exlink [H]ardness Supreme
    4,151
    Dec 16, 2006
    I always go for the fastest single card that I can afford at the time, which appears would be a RTX 2080 Ti in your case.
    Parja likes this.
  10. spintroniX
    spintroniX Gawd
    959
    Apr 7, 2009
    The 2080Ti is sweet. I must be lucky because I've had no issues. One runs nearly 24x7 for deep learning tasks, the other intermittently for the same, and occasionally for gaming. Maybe 10 hours of gaming on it so far (and several times that with deep learning) and no space invaders action.
    Maddness likes this.
  11. The Cobra
    The Cobra 2[H]4U
    2,589
    Jun 19, 2003
    Well, I am back to team green after 9 years. Disappointed with the reviews of the AMD VII so far. So I just plunked down $1600 for a pair of 2080's.
  12. XoR_
    XoR_ Gawd
    654
    Jan 18, 2016
    Radeon VII disappoints...
    barely 1080Ti performance at 2160p and RTX 2070 performance at 1080p
  13. Maye88
    Maye88 n00b
    7
    Jan 14, 2019
    The rumor is it works better with AMD cpus and apparently, it really really likes the TR series. I'm skeptical, but we'll see.
    Also if you add washers to the heatsink screws contact is much better and it will drop the junction temp by 10C.
    Either way, my card has arrived so I'll be benching it alongside my 1080ti on my 1950x system. I'll report back.
    primetime likes this.
  14. Digital Viper-X-
    Digital Viper-X- [H]ardForum Junkie
    13,565
    Dec 9, 2000
    are you doing 4k video editing? :p
  15. Maye88
    Maye88 n00b
    7
    Jan 14, 2019
    Scientific compute.
  16. primetime
    primetime [H]ardness Supreme
    5,522
    Aug 17, 2005
    Ill give ya 300 for one of those peace of shit Radeon Vega frontier edition 16gb cards;)...I think you should have went with a single card 2080ti but i guess your going to be doing hard core cuda that can use both?
    The Cobra likes this.
  17. The Cobra
    The Cobra 2[H]4U
    2,589
    Jun 19, 2003
    Def not a piece of shit. :-P Check you msg inbox. I still do some editing with Adobe, so the cuda cores will come in very nicely. But my computer is def more gaming oriented because I don't use it for work anymore all that often.
  18. primetime
    5,522
    Aug 17, 2005
    always loved the frontier edition cards.....only thing better is water cooled models. they should hold certain value from kinda a collector standpoint cause like the vega7 there just a small amount being made. I be really happy when they get better at using the opencl compute side of the cards like cuda
