Radeon VII and Samsung un43ku7500fxza no automode to PC on HDMI1
Discussion in 'AMD Flavor' started by Crowley, Mar 23, 2019.
  1. Crowley
    Crowley n00b
    16
    Apr 25, 2007
    I recently got a new rig and this one runs a radeon vii. Previously I had a GTX 980. W/ the 980, it would allow my samsung un43ku7500fxza hdmi1 to auto choose PC(mode). With the radeon card, I have to manually choose it when I boot. Does anyone have any idea if there is a setting in the AMD settings that may fix this?
    thanks,
    Crowley
  2. Pieter3dnow
    Pieter3dnow [H]ardness Supreme
    6,433
    Jul 29, 2009
    From my Samsung TV (not the same model) I think you can define what is going to be used for that slot. There should be a Samsung TV menu displaying HDMI options for each HDMI slot.
  3. Crowley
    Crowley n00b
    16
    Apr 25, 2007
    This is correct and I set it for PC, However, when I reboot, it defaults back to HDMI-DVI (something like that). When I had the GTX 980, it would auto choose PC so I never had to worry about changing it.
    Thanks for the quick reply though!
    Crowley
  4. Pieter3dnow
    6,433
    Jul 29, 2009
    Which part is not doing what it is supposed to the TV or the PC ?
    I never had this problem what I do know that there is a large topic in the display forum section about how to get a TV as monitor working.
  5. Crowley
    Crowley n00b
    16
    Apr 25, 2007
    I'll try over there as well .. honestly I don't know which side it is on, although I make the change to PC Mode on the TV. I just didn't have to do that with the Nvidia card as I guess it must have sent some signal to the TV that it was coming from a PC (the TV would automatically choose PC mode).
  6. sirmonkey1985
    sirmonkey1985 [H]ard|DCer of the Month - July 2010
    21,072
    Sep 13, 2008
    Could be the color settings in the driver's not defaulting/set to 4:4:4 or 4:4:2 or what ever the TV supports so the TV isn't auto switching. That's just my guess.
  7. Dayaks
    Dayaks [H]ardness Supreme
    6,655
    Feb 22, 2012
    I’ll be honest I don’t understand the question. I do know my JS8500 saves the settings per input. So when I switch to the input of my HTPC instead of xfinity all the settings are already right....
