Radeon Vanguard open beta tester spots.
THUMPer
*Radeon vanguard open beta tester spots*
From Phaszr
I'm opening up more Vanguard beta tester spots, and am reaching out here on Discord right to the AMD community! Keep in mind I won't be able to accept everyone for various reasons but if you are selected you will get an email or a reply in PM from me.
Step 1: Apply here (if you haven't already): https://www.amd.com/en/technologies/radeon-software-testers
Step 2: When you've done that (or did it before), PM me your GPU(s) and your email.
Step 3: Profit if selected.
Please remember this is an NDA'd program and your involvement requires radio silence externally about our specific activities. You can definitely mention you are in Vanguard of course! We get to play with cool stuff and you have direct access to speak with AMD engineering and marketing through myself and many AMD staff in the discord. I want to stress this is of course volunteer stuff, so don't treat it as some sort of work. I never want it to be that way. If you want to help me help everyone when we post a driver to the web, and get those sweet bug fixes early, apply. Don't like something in the software? Want to make a suggestion or feedback straight into AMD engineering, through myself? Apply. I'm looking for active and friendly members.
We've grown into a tight community with mutual respect for each other. I have zero tolerance for racism, sexism, bullying, etc. You'll be removed. Thanks!
This is open to all AMD GPU users though. We use Discord, and we usually have weekly driver builds for all products, even mobile. There is a dedicated bug reporting channel, which is moderated by AMD, and is a fantastic resource. PM your email address you used to sign up with your GPU model and I will get the info over to the correct place.
I have twin Vega FE's, use Modo which now supports Pro Render in v13 - buggy as hell when using Pro Render - constant hard crashes to point of resetting bios is needed. Anyways is there a more Pro section for beta testing?
There is a group for pro, but they are in their own world, and don't adhere to the gaming beta schedule.
Thanks for the reply, I don't think at this stage I would be Pro enough - 9 years ago different story. Getting serious again with 3d which should take me through my later years on this planet I hope.
Not sure if this is still an active program but I do have a navi card and a new amd rig to test with. PM incoming
just submitted request to join program. .. I guess I'll find out soon enough if I am worthy .. o_O
Too bad my only AMD GPU is an old Radeon HD 7970 modded to a GHz Edition.
