Radeon Software Crimson ReLive Edition 17.5.2
Discussion in 'AMD Flavor' started by ecmaster76, May 18, 2017.
  1. ecmaster76
    ecmaster76 Gawd
    786
    Feb 6, 2007
    New Radeon drivers:
    http://support.amd.com/en-us/download/desktop?os=Windows+10+-+64
    http://support.amd.com/en-us/kb-art...mson-ReLive-Edition-17.5.2-Release-Notes.aspx
    Support For
    • Prey®
      • Up to 4.5% performance improvement measured on Radeon RX 580 8GB graphics when compared to Radeon Software Crimson ReLive edition 17.5.1(1)
    Fixed Issues
    • NieR™: Automata may experience a random hang or application crash after short periods of gameplay.
    • Forza™ Horizon 3 may experience very long map/launch load times.
    • The primary display adapter may sometimes appear disabled in Radeon Settings while driving a display from the linked adapter in Multi GPU system configurations.
    • Radeon RX 550 series graphics products may experience a system hang when entering sleep or hibernate modes.
    I can confirm Forza fix finally works. Windows 10 "helped" by pushing one of the broken drivers the other day so this is good timing.
    PS - Its slow in here. I know there is a lot of thread crapping lately but still...
  2. NoNRG
    NoNRG 2[H]4U
    2,129
    Dec 16, 2007
    Thanks. Windows Update on Windows 10 also broke my video driver install yesterday, so this helps. Hopefully they don't try "helping" me again.
  3. sonsonate
    sonsonate Gawd
    690
    Mar 15, 2012
    Yeah, that's some annoying "ish", but in case you don't know, you can go to the device manager and rollback and make it so it doesn't update it automagically. Not sure how long that lasts, but it helped me out a couple days ago to go back to the driver version I had just installed without having to wipe a thing.
  4. rgMekanic
    rgMekanic [H]ard|Gawd
    2,010
    May 13, 2013
    The other thing I've found if you want to get rid of the windows 10 crap is do a full uninstall with DDU, re-boot with your network cable unplugged, then install what you want heh
