If you use a single card and Afterburner, with unofficial overclocking enabled......I honestly can't see the benefit.....except for the new "Boost" features?
That's right, you can oc to the same values, so i don't see the point.
Can anyone give instructions on how to flash back to the original BIOS just in case?
Can't you just use the bios switch?
You shouldn't use atiwinflash on a video card without a dual bios. Also it doesn't hurt to load up optimized defaults before booting into DOS to flash.
Why do you say that?
If the GHz BIOS doesn't take, you simply reflash to the saved original BIOS.
I've used ATIWinflash on several HD 6950 cards that had no dual BIOS and there was no problem.......on two of the cards the shaders didn't unlock, so I simply flashed the card back to the stock BIOS...... I did use MS-DOS commands however.
What happens if you have a bad flash or there is some sort of other issue? Do you know how to blind flash? That isn't going to happen from Windows, thats for sure.
It never hurts to minimize variables.
If something happens where you temporarily brick your card from a bad flash, you can just boot up using a spare card, or even integrated graphics then reflash using the original bios. And remember to always back up your original bios.
Why people choose to do this instead of just overclocking it is beyond me.
most unneeded flash ever?I completely agree. Just overclock the card to 1050 (I haven't seen a 7970 that won't hit this number) and be done with it. No bricking the bios, no fuss, no muss.
Not necessarily.
This BIOS will allow higher clocks directly in the Overdrive function of the CCC.
This would be an advantage in Crossfired configurations.
Most if not all the current third party software doesn't like Crossfire.
With this flash you don't have to fiddle with the ULPS, no "enable unofficial overclocking" no nothing.
I see some definate benefit. Of course the cards can do 1050 standing on their heads. My son's run at 1125/1500 all day long.
Not necessarily.
