Deathwish238
- Oct 11, 2006
This is driving me nuts. I have a freshly installed Windows XP on a system that is serving as my HTPC.
Sapphire Radeon 5450 using HDMI to a 42" Panasonic 720p Plasma
Athlon 64 X2 3800+
Asus A8N-SLI Deluxe
2GB DDR RAM
120GB HDD
I typically set the resolution to 1280x720. If I open XBMC, as soon as I close it the resolution will revert to 720x480. If I restart the computer, the resolution will revert to 720x480.
I have tried the latest 3 drivers from AMD and am trying some older ones now just to see if they'll work versions 10.12 and 9.12.
How can I make the resolution stop reverting?
Athlon 64 X2 3800+
Asus A8N-SLI Deluxe
2GB DDR RAM
120GB HDD
