Rack Chassis That Supports Water Loops?
Discussion in 'Cases & Case Modding' started by The_HAVOK, Jan 4, 2020.
  1. The_HAVOK
    The_HAVOK n00b
    7
    Dec 24, 2019
    Does anyone know of any rack-able chassis that you could fit a 240mm or 280mm AiO radiator?
    That is really the only requirement that I have, that it be able to mount at minimum a 240mm radiator.
  2. thesmokingman
    thesmokingman [H]ardness Supreme
    5,632
    Nov 22, 2008
    There's a few builds usually with a Rosewill RSV-L4000 rack case. Regardless of the case the result is the same, stuff a 360mm rad in front.
  3. w1retap
    w1retap [H]ardForum Junkie
    12,021
    Jul 17, 2006
