R9 Fury 4gb $240AR
Discussion in '[H]ot|DEALS' started by buhbuhfet, Jan 8, 2017.
  1. misterbobby
    misterbobby 2[H]4U
    3,097
    Mar 18, 2014
    240 bucks after rebate for that card does not seem hot to me at all. The Fury is only 10-15% faster than the RX480 4GB which can be had for for under $200 with no rebate and as low as $170 after rebate.
  2. D1RTYD1Z619
    D1RTYD1Z619 Limp Gawd
    348
    Aug 11, 2012
    Not to knock on your find but 240 before rebate would be a "hot deal". The lack of HDMI 2.0 though makes me Furious. Did you see did you see what I did there?
  3. AngryLobster
    AngryLobster [H]Lite
    104
    Aug 24, 2016
    You're reaching pretty hard.
    http://www.ocaholic.ch/modules/smartsection/item.php?itemid=4008&page=15
    20% for $40-50 is a substantial gain. That is the same difference between a 1070 and 1080 except they are $200 apart. This isn't even taking into account the bottom of the barrel cooler a $200 RX 480 has compared to the Fury's that rarely breaks 1000 RPM undervolted.
    IMO for people looking for something to get by until Vega drops, Fury Air is a no brainer but they've been priced lower than this.
    tungt88 and Archaea like this.
  4. misterbobby
    misterbobby 2[H]4U
    3,097
    Mar 18, 2014
    Oh so I guess your link supersedes anything I could come up with so that means I am reaching hard? :rolleyes:
    https://tpucdn.com/reviews/MSI/GTX_1070_Quick_Silver_OC/images/perfrel_1920_1080.png
    The Fury is under 14% faster than the 480 here. Even going by your link of 20% the 480 is the better buy for 170 bucks AR. So as I said, for $240 AR it does not seem hot to "me".
  5. Stormside
    Stormside Gawd
    591
    Jun 27, 2003
    Unless your gaming at 1440p then it makes all the difference.
  6. buhbuhfet
    buhbuhfet Limp Gawd
    451
    Feb 11, 2016
    yeah not that hot but decent, id buy fury over 480/390 tho
    ManofGod likes this.
  7. harmattan
    harmattan 2[H]4U
    3,956
    Feb 11, 2008
    Unless you have another Fury already and really, really want to try (and likely be disappointed by) x-fire, I don't really think this is a hot deal at this point. That said, there's nothing really this good in the $240 range and I'd take this over an overclocked GTX 1060 6GB (which tend to cost a bit more than $240).
    If you win the lotto and get one that unlocks, then I'd say it's very hot.
    Thanks, in any case, for passing along.
  8. ragnarz
    ragnarz [H]Lite
    100
    Feb 22, 2006
    What do you mean by "unlocks"?
    thx
  9. Archaea
    Archaea [H]ardness Supreme
    7,971
    Oct 19, 2004
    What games disappoint in crossfire? All of mine have worked that I've tried.
    Doom
    Shadow of mordor
    Witcher 3
    Dirt rally
    Depth
    Shark attack
    I think that's about all I've tried so far. I've only had crossfire a couple weeks but everything I've tried has worked flawlessly on my Fury X cards. Performance gains range of course but everything has been positive improvements that I've tested. I think crossfire has come a long way from the opinion some people formed years ago.
    Seems like crossfire performs exceptionally well even 1.5 years ago in these tests.
    http://www.tweaktown.com/tweakipedi...re-triple-4k-eyefinity-11-520x2160/index.html
  10. LakeErieWater
    LakeErieWater [H]Lite
    66
    Aug 22, 2011
    I've had good experiences too with crossfire and I'm even using 2x 7970 still going strong. Most major titles support crossfire and if they don't you likely don't need it to drive to high settings anyhow.
  11. WhoBeDaPlaya
    WhoBeDaPlaya 2[H]4U
    2,555
    Dec 16, 2002
    Another happy Crossfire user with 2x 290 @ 290X.
  12. harmattan
    harmattan 2[H]4U
    3,956
    Feb 11, 2008
    I've had Crossfire solutions every gen since 1900xt (and SLI further back before that), my last being dual 390xs. I finally gave up, moving back to a single GPU. Like SLI, I'd say around 40-50% of games in my xp have some issue ranging from annoying to being completely non-functional... and the support seems to have gotten markedly worse over the last two generations. Of those titles alone, the first three of them had major x-fire issues for months after release (with some still existing): Doom, Shadows of Mordor, and Witcher 3. Then there's microstutter... something I realize not everyone notice - I do. Further, there's the invariable waiting for support of new tech e.g. Freesync, VR during which your investment is wasted if you want to adopt.
    The only time I'd suggest going mGPU is if you absolutely can't reach a mimimum FPS with a single GPU at the res/IQ you want to play at.
  13. _chesebert_
    _chesebert_ n00bie
    47
    Nov 2, 2016
    My locked fury does 8350 on GPU score in Firestrike extreme. I think op will be fine with a bit of overclocking.
  14. 257Tony
    257Tony Gawd
    721
    May 18, 2011
    Doom has no crossfire support at all.
    Ocellaris likes this.
