kamikazi
- Jan 19, 2006
I turned the case every which way but loose ;-). I shook out a lot of bubbles. I did the Mayhem's part 2 I think before I filled it up with Koolance fluid. With the Mayhems, I ran it overnight, then flushed it with distilled water 4 times per the instructions. However, I don't think I got all of it out due to how the components and the tubing in the case is situated. I certainly diluted the heck out of it though. I think there is just enough left to allow it to bubble where it enters the reservoir. If you look at the first picture I posted, you can see the bubbles up top. Some of the very tiny bubbles somehow get sucked all the way to the bottom when the pump is at 100%. I need to put a little more Koolance in through my fill port to try an cut down on the air space in the reservoir some more and I guess I need to shake it out. I know air can cause inefficiency, but this seems extreme.There really should not be bubbles moving around inside your loop after the system hits stability after being filled.
It sounds to me like your issue may be that you still have air trapped in the system.
A few thoughts:
1.) Did you do "case gymnastics" after your fill? Varying pump speed up and down and leaning the case on its sides and front and back up again, while the pump is running to try to get all the air out. You can keep tilting and banging the system around for hours and still not get all the air out. This is usually necessary to get all the air out of the system. With some systems it clears out on it's own over time, but with others depending on the loop and how easy it is for freed bubbles to get sucked back in, it doesn't and needs lots of case movement
2.) What do you use as your coolant? Air bubble problems are a lot less rare if you use a coolant that contains a good surfactant. If you just use straight distilled water you are going to get much more air caught in the system.
