r7 2700x or i7 8700k
Discussion in 'AMD Processors' started by Sherloc09, Oct 19, 2018.
  1. Sherloc09
    Sherloc09 Limp Gawd
    312
    Jul 22, 2017
    Both builds are approximately the same price, with a slight edge to Intel due to memory QVL limitations on AMD side. Am on the fence and was looking to see if Intel brought anything to the market with the 9th series chips, but doesn't look to be a good value proposition. Thinking of value, am now sliding towards AMD Zen+, as the platform has room to grow with support for future Zen2 processers and maybe others beyond that, but for the price on PCPartPicker spec'd builds, the 8700k actually wins out due to the memory being cheaper.
    Both builds include NH-D15, top end [non-LN2/DICE focused] motherboards, 32gb ram [3466 vs 3600 respectively], Meshify C Non-TG, 5x Noctua NF-A14 PWM, 1000watt EVGA PSU, and a Silverstone PWM Controller. Already purchased a MSI Gaming X GTX 1080 TI, which will be the GPU.
    Use Cases
    Primary = 4K Gaming
    Secondary = Internet perusal
    Tertiary = None, no streaming, content creation, etc.
    Closing thoughts
    Since the 8700k is marginally better in gaming applications, would it be the better choice, and if not, help me side with AMD on this one.
    Thanks.
  2. jmilcher
    jmilcher 2[H]4U
    3,969
    Feb 3, 2008
    For that use situation the 8700k would be fine.
    Any more multitasking, or focus more on general use, and the 2700k wins hands down .
  3. pavel
    pavel Limp Gawd
    177
    Apr 8, 2014
    I think you mean, the 2700X 'wins hands down?' ;-)
  4. Sherloc09
    Sherloc09 Limp Gawd
    312
    Jul 22, 2017
    Leaning towards the 2700x. Mainly because want to support AMD, and at 4K most games won't tell much a difference between 8700k and 2700x on current gen GPUs.
  5. Pieter3dnow
    Pieter3dnow [H]ardness Supreme
    6,251
    Jul 29, 2009
    And if you want you can pick up a next generation AMD cpu after this year if you are in dire need. As it seems now the 7nm desktop cpu is going perform better a lot better.
    otg likes this.
  6. kirbyrj
    kirbyrj [H]ard as it Gets
    23,622
    Feb 1, 2005
    I have a similar build including a Meshify C, evga PSU, 32GB RAM (I have FlareX though), and an MSI Gaming X. I haven't been disappointed. I've used both the 8700k and the 2700x and I really can't tell the difference between the two at 4k. It's not a scientific benchmark. I just play games and see if I can feel a difference.
    Sulphademus likes this.
  7. Sherloc09
    Sherloc09 Limp Gawd
    312
    Jul 22, 2017
    Yep, albeit at 4K we'll probably be bottlenecked by GPUs until the 3080 series or beyond.
  8. Sherloc09
    Sherloc09 Limp Gawd
    312
    Jul 22, 2017
    Benchmark comparison at 2880p and 2160p, between the 8700k and 2700x.
    Neon01 likes this.
  9. kirbyrj
    23,622
    Feb 1, 2005
    So realistically you won't notice a difference. The 2700x is about $50 cheaper and you can always drop in a new processor later to the AM4 board. Z390 probably won't get more processor support if Intel follows their chipset money grab ways.
    LightsOut41 likes this.
  10. Furious_Styles
    Furious_Styles Gawd
    994
    Jan 16, 2013
    Way overkill on the PSU unless you are going to do SLI. If you're doing 4k it's going to be GPU limited most of the time so I agree with some others just get the cheaper option.
  11. Sherloc09
    Sherloc09 Limp Gawd
    312
    Jul 22, 2017
    The PSU was an EVGA 80+ Gold Rated 1000 Watt PSU for $99.99. Getting it more for the great value. It's since gone up to $135, so probably going to hold off as I don't need it; have a 950 Watt non-modular Corsair.
    TMCM likes this.
  12. Furious_Styles
    Furious_Styles Gawd
    994
    Jan 16, 2013
    You could get by with a 650 easy, even a 550 would work. Though the cheapest would certainly be to use that 950W corsair!
  13. Sherloc09
    Sherloc09 Limp Gawd
    312
    Jul 22, 2017
    Yeah, the Corsair is a beast, have had it near on half a decade at least. Figure it's better safe to get a replacement lined up when the price is right.
  14. Furious_Styles
    Furious_Styles Gawd
    994
    Jan 16, 2013
    Yep, if you're in the US some good sales should be coming up relatively soon.
  15. Brackle
    Brackle Old Timer
    7,224
    Jun 19, 2003
    You could also buy a 2700 non X for cheaper, overclock it to 4.2ghz and get the same performance as the 2700x. Save over $100!
    kirbyrj and N4CR like this.
  16. N4CR
    N4CR 2[H]4U
    3,372
    Oct 17, 2011
    Can look at it this way... Cpu limitations are a thing if you want to go high hz in future. One platform has an upgrade path that will go beyond the other, likely with more cores to boot.
  17. Sherloc09
    Sherloc09 Limp Gawd
    312
    Jul 22, 2017
    True, though the $ isn't an issue in the price range of the 2700x vs 8700k. Figure I'm going to get the 3600mhz RAM that isn't on the QVL since another reviewer mentioned it works on his x470 at 3466 mhz. So, instead of going QVL I'll save ~$100 on ram and maybe downclock it to the QVL rated kit if 3600mhz isn't stable.
  18. Brackle
    Brackle Old Timer
    7,224
    Jun 19, 2003
    Sometimes the clock speed of the memory can be slower than faster timings. Read around first before thinking 3466mhz will be better.
  19. Ahh shit I thought this was the [H] forums.
    Save $100 or more and get a bare 2700 if you're buying an AIO or aftermarket cooker, spend maybe ~20 minutes manually overclocking to same speeds as 2700x. Profit.
    Spend extra on next gen GPU...
    otg and DrLobotomy like this.
  20. Brackle
    Brackle Old Timer
    7,224
    Jun 19, 2003
    I sold my 2700 non X heatsink for $20 :)
    /dev/null likes this.
  21. Sodapopjones
    Sodapopjones [H]ard|Gawd
    1,795
    Aug 22, 2012
    Son, I got my 2700X for $249 with no tax, it really boils down to what deal you can find.
    Sulphademus and Brackle like this.
  22. KingGlade
    KingGlade [H]Lite
    105
    Dec 15, 2016
    Damn, that's a good deal! I was happy I got mine for $299.
  23. Sodapopjones
    1,795
    Aug 22, 2012
    Refurbforless on ebay often has good deals if you don't mind waiting for your order.
    Kursah likes this.
  24. likeman
    likeman Gawd
    585
    Aug 17, 2011
    If you don't want to go down the tweaking of overclocking the 2700x is the better option as out of the box it's already running at its near best automatically (where the 1000 cpus you needed to overclock to get best out of it)
    overclocking manually actually harms single threaded performance on the 2700x
    I have the 1800x right now 3.9 all cores (waiting for 3000 cpus as 2700x would be a minor upgrade from what I have, the 3700x should be a step up)
  25. KingGlade
    KingGlade [H]Lite
    105
    Dec 15, 2016
    Thanks, man! I'll save that to my bookmarks and use them in the future. I can be quite patient for a good deal.
  26. Sherloc09
    Sherloc09 Limp Gawd
    312
    Jul 22, 2017
    Went with the 2700x.
    c3k likes this.
  27. MrC4
    MrC4 [H]ard|Gawd
    1,296
    Feb 10, 2010
    Nice. I made the same decision a few weeks back and have not regretted my decision for a second.
  28. Mchart
    Mchart 2[H]4U
    2,898
    Aug 7, 2004
    This is my first AMD CPU since the Athlon X2. Went with the 2700x because it was cheaper, and with 4k gaming there is basically no difference. I also like the 'install and forget it' precision boost 2. Finally, AM4 still has some life left on it, and i'm very familiar with Intel's short chipset/socket life spans.
    LightsOut41 and cyberguyz like this.
  29. Sherloc09
    Sherloc09 Limp Gawd
    312
    Jul 22, 2017
    Went 2700x because... well, to be honest, I'm favoring AMD's business strategy and their attempt to provide value and innovation to the market segments that Intel has been slow to offer -- ostensibly to maximize profit. Could have gone 9900k, RTX 2080 TI this upgrade season, but ultimately NVidia's and Intel's money grab sort of put me off their top tier products. Opted for a GTX 1080 TI and 2700x, the 1080 TI was first purchased, and albeit Intel does have an analogically similar counterpart release in the 8700k, AMD seems to have made good strides to help out the average consumer. Thus purchased the 2700x to "vote" with my dollar on what I like to see in a business.
    Meeho likes this.
  30. elite.mafia
    elite.mafia Broke Back [H]
    10,850
    Aug 23, 2004
    8700k is better for gaming, hands down. If you are after the absolute best framerates and are stuck between those 2 CPU's, the 8700k is a little better.
    shaolin95 likes this.
  31. Mchart
    Mchart 2[H]4U
    2,898
    Aug 7, 2004
    At 4k there is almost no difference to the point where the variance could just be the motherboard, RAM speeds, etc.
    Maybe if you're the 1080p or below 144hz+ twitch gamer crowd, but anyone else it's a wash. Ultimately the 2700x offers more value, and with the life of the AM4/x470 even increases that value.
  32. Sherloc09
    Sherloc09 Limp Gawd
    312
    Jul 22, 2017
    I would have gone 9900K most likely since it would be cheaper going 9900K than buying the Zen+ 2700x, then upgrading later to a <= AMD cpu compatible with x470. If you look at it that way, 9900K is a good bargain, as you'll be getting the Zen2 or greater performance today, rather than waiting a six months+, and having to upgrade twice. Ultimately at 4K though, I can vote with my dollars on what is in my opinion a better business strategy being employed by AMD than Intel. The 9900K should have released for ~$400, and been called the I7 9700K, the 9700K the 9600K and 9600K the 9400[K]. After a few years if 4K is being held back by the 2700x, I'll see what offerings Zen2 or Zen3 have brought to the table and can make a purchasing decision at that point, or hold out for my next ~6 year platform upgrade.
  33. Sherloc09
    Sherloc09 Limp Gawd
    312
    Jul 22, 2017
    For those that want to see the build, will be posting up pictures once all parts have arrived. Part list in signature.
    craigdt likes this.
  34. Sherloc09
    Sherloc09 Limp Gawd
    312
    Jul 22, 2017
    Have to say, holy s***. Just put together the pc, and with 6x140mm + 2x150mm Noctua's installed + MSI GTX 1080 TI Gaming X, it's completely, I mean completely silent at idle. I hear my ac pumping heat through the house, but nothing from the pc. Just checked AMD Ryzen Master and seeing mid-30s on the CPU sitting in the 4.175 ghz range with its base turbo boosting it.
    For those who are wondering, fan configuration is two 150mm on the D15S pointing at rear exhaust. One 140mm exhaust at the rear. Two front and two top 140mm intake. The idea is that the intakes are blasting the D15s, then the heat is pumped directly to the rear exhaust fan. The PSU is pulling air from the GPU directly down and out the case through the PSU shroud.
  35. Mchart
    Mchart 2[H]4U
    2,898
    Aug 7, 2004
    Go into your bios and up the EDC to 168 or just enable auto PBO.
  36. pippenainteasy
    pippenainteasy Limp Gawd
    508
    May 20, 2016
    AMD chips run so much cooler than Intel it's crazy. I just built a 2700X mini itx box and the thing runs cooler than a 8700K delidded with liquid metal with the same cooler...meh definitely going Zen 2 for next gaming build, tired of seeing furnace temps.
  37. OrangeKhrush
    OrangeKhrush [H]ard|Gawd
    1,356
    Dec 15, 2016
    I bought a 2700 and went stock fan, I do like the stock fan look and it is copious for my needs, got a good deal on a ITX board so I was able to just swap it out. I am admittedly not a guy that requires max threads at max clock, I just put it in and go. I don't really notice that much difference in gaming even though some benches say the 4790K is faster, in games I did notice a difference was in Scum, the 4790K despite high FPS was stuttering more.
  38. BoiseTech
    BoiseTech Limp Gawd
    276
    Mar 15, 2018
    8700k is so damn hot, but then again it is slightly faster than the 2700x in single core workloads. Is your need multi-thread based, or single-thread based?
    I have a 2700x and just upgraded my 8700k to a 9900k. Honestly I can't pick a favorite. The 9900k is on par with the 2700x heat wise. But per dollar, they're all great.
  39. 5150Joker
    5150Joker 2[H]4U
    2,884
    Aug 1, 2005
    Could you have picked a more biased and meaningless benchmark video? The 1080 is a major bottleneck at that resolution and even a 2080 Ti would be the bottleneck. I get the OP has a 1080 Ti but at 4k it is a major bottleneck which isn't indicative of cpu performance.
    OP: Either wait for Ryzen 2 or get a 9700k which has the benefit of 8 cores vs HT in 8700K. This could be useful in the future as games like BF V start using more cores. You can easily OC a 9700K to 5 ghz with around 1.3v and at most a 3 avx offset if your chip isn't a silicon lottery winner. At those clocks the 2700x breaks even with it in applications like rendering while the 9700k has a sizeable lead in single core performance.
    PS That 1080 Ti isnt enough for 4k 60 fps having.
  40. Westwood Arrakis
    Westwood Arrakis Limp Gawd
    406
    Nov 17, 2012
    OP, just wanted to say thank you for fortifying my decision on a 2700x for my next build.
