Good evening, fellow [H]ers. I'm trying to make a quiet yet powerful build that also consumes very little power just because I like conserving energy. I already have a few of the components from picking away at random awesome specials, but let me get these out of the way:
Medium to heavy gaming (EVE, random new games like Skyrim), light video encoding.
Budget not relevant but super expensive parts will not likely be useful
Chicago, IL, USA
Motherboard, GPU, hard drive (want a 512-ish GB SSD), sound card, DVD +/- RW, CPU cooler (I'd like to use the True Spirit 120 if it ever gets sold anywhere other than Nan's)
Case (Fractal Design Arc Midi), CPU (i5-2500k), power supply (Kingwin STR-500), RAM (16 GB, 4x4 GB), OS (Windows 7 64-bit)
6) Will you be overclocking?
If anything I'd like to underclock by dropping the voltage down as far as I can get it while keeping it as close to stock as possible,. Green's the name of the game.
23",1920x1080
Over the next 1-2 months; assembling parts as I find good deals
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
SATA 6, USB 3 are required at this point. PCI-E 3.0 isn't popular enough unfortunately or I'd want it just to be forward-looking.
I have Windows 7 64-bit already.
I think I'd like to wait for the ATI 7k series to come out completely so I can pick the best balance of power/efficiency. Unofficially, my goal is to use no more than 4 fans total, but I will not cut out fans at the expense of making my components run hot.
So far, I'm thinking:
Motherboard: ASUS P8P67 (REV 3.1)
GPU: ?
HD: ?
Sound card: ? - good for gaming is nice but I have a 2.1 setup
HD: ? - perhaps Crucial M4? Not sure if another will come out soon
Open to all ideas, suggestions, and critiques. Thanks for reading this far.
Chicago, IL, USA
23",1920x1080
GPU: ?
HD: ?
