velusip
- Jan 24, 2005
Just trying to quiet this rig and the stock AMD HSF is the noisiest component... so here it goes:
Apparatus
Running Folding@Home for more than a day.
Data
These are 100% load temperatures 100% of the time.
Conclusion
Now, that's performance! My temperatures are so much higher, it must represent how much [h]arder my computer is. It must.
Seriously though, I'm yet to do some resetting, but for now even after installing the Zalman replacement HSF the noisest thing is still the HSF even with the resistor installed. Mind you, it is much quieter than it was, but at a cost of redlining constantly. (75 is a high threshhold for this particular processor, but 95 is the theoretical limit before instant damage)
Sure this proc is fast, and seems to outperform similar Athlon 64 procs [2800..3200], but it runs so damn hot it's hard shut it up! For this reason I do sort of regret going with SocketA. I should also note that despite I live in Canada, my house is about thirty to forty degrees. Can't help that living in the top floor of an A-frame with 3 computers running 24/7.
Follow up
After making sure the HSF was set "perfectly", no changes. Then after removing the resistor from the Zalman fan, temperatures went down to Sixty-two degrees at full load. Exactly the same as it were with the stock HSF and no, it is not quieter than the stock HSF (it might be by very little, but not noticable). All in all this Zalman HSF is a waste of money...
Apparatus
Data
- stock HSF: Sixty-two degrees.
- Zalman Flower: Seventy-three degrees.
Conclusion
Follow up
