My girlfriend is getting ready to order a MacBook Pro. I think she should downgrade the 'stock' 1x1gb to the optional 2x512mb and save $100. Her dad wants her to spend the extra $100 for easy upgrading later. Her dad trusts and values my opinion, but has basically said "thanks but no thanks" since he has no one else telling him the same thing and "why would apple charge $100 more for a useless upgrade?"
I told her I think that is foolish to keep the 1x1gb for the following reasons:
1) She does basic chatting and websurfing. I dont think she will ever need more than 1GB. Spending money for future upgrade ease if you wont need to upgrade is foolish.
2) No dual channel. 1x1GB can not take advantage of dual channel memory controllers. Therefore, the 2x512MB will actually be slightly FASTER than the 1x1GB (how accurate is this?)
3) Upgrade costs. A single 1GB stick will cost about $80. To get to 2GB starting witha single 1GB stick will cost her the $100 to upgrade to the original 1GB + the $80 to buy a second stick.
The 2x512MB option: It will cost $160 for 2x1GB sticks. vs the $180 by starting with 1GB. $20 savings, no big deal. However, the 2x512MB can turn around and be sold for ~$50. Now it's a $70 savings.
So if she doesn't upgrade, she will get dual channel with the 2x512MB, and save $100.
If she does upgrade from the 2x512MB she will save $20, Plus an additional monies from resale of the 2x512MB if she decides to sell them.
4)Personal Grievance: she had a toshiba. It basically broke. She brought it to CompUSA who reported it had "160 viruses on it" and then later reported that it actually had hundreds more than that. So her rationale is "Macs dont get viruses!" Ugh. Okay, play an extra $1000 for a white case with an apple on it, and antivirus. Or save $1000 and get a Dell or something and use a REAL ANTIVIRUS and not rely on AOL Antivirus. /rant 0
Opinions? Besides "it will be too much work to take them out, install different ones, and sell them, etc." b/c im going to do that for her.
Thanks!
Edits made to correct confusion. Also, my 2x512MB 533mhz went for ~$50. 2x512MB of 667 will sell for even more.
Thanks!
