****Update*****
In case you haven't heard about the three-hundred-dollar-bandit of a 24" LCD that is the SOYO DYLM24D6, they you should brush up here and here.
Many of us geeks and forum dwellers are experiencing the pain of making multiple trips back to Office Max to give them their POS back. You'll see me in those threads, first overjoyed at the bargain I had scored, and then later on tensely awaiting the death my 3rd Soyo in less that a week. So far #3 hasn't died on me yet. But, in my eager certainty that the Soyo will break imminently, and knowing that I wasn't going to accept exchanging for a fourth, I decided I'd give the Westinghouse L2410NM a shot.
There isn't much info about the Westinghouse out there. But, since BustBuy had it on sale for $400, I figured I could get it, and take it back if it sucks. (You can also get it at Newegg for $360 after MIR) I couldn't do much worse than the Soyo. So I'm going to take this opportunity to (subjectively) tell you how these monitors compare when they are side by side. Let me say this up front, the IQ difference between these two monitors isn't large, and you'll have to be looking pretty hard (like I am) to see the differences. Having them side by side would be the only way to tell them apart.
Now I'm currently positioned in front of these two beautiful 24" monitors. I spent about 2 hours calibrating both of them to get the best possible picture, without using any software or driver based image enhancements. I used a combination of checkemon, this web site, and this thread to help me get these monitors calibrated. When I got done, the desktop and solid color tests were identical between the two monitors. With that done, I spent the next three hours doing side by side comparisons of the monitors in movies, flash video, desktop apps, and in TF2.
Here's a list of the final settings I settled on with these monitors
......................Westy:...........Soyo:
Brightness:...........70.................30
Contrast:..............80.................60
Red:....................32.................38
Green:.................32.................38
Blue:...................38.................38
Image Quality:
Read Here
Gaming:
All's well here. No noticable or lagging ghosting on either monitor.
OSD:
Just be warned. The on screen display for both of these montors sucks big time. The westinghouse is annoying because the menu button is also the source selection button. As well, the power button is easy to hit by mistake while you're trying to make adjustment. The soyo is also very non-intuitive............
Viewing Anlge:
I didn't do any special tests here. I just quickly moved around the room while looking at the screens. I would seem the Westinghouse does a bit better at side-to-side view angles, but it does substantailly worse at vertical viewing angles
Miscellaneous:
1)
The westy's stand isn't quite as cheap as the soyo's, but niether one is capable of verticle adjustment. The Westy is about 1/4" taller than the soyo.
2)
with the Westy, you'll need to buy a DVI to HDMI cable, as it does not have a DVI port. DO NOT pay $70 bucks at a retail store for one of these cables. You can buy them online for $10 bucks. However, I was anxious to compare, so I went to Wal-Mart and bought a very nice RCA DVI to HDMI cable for $30. (they had another brand for 2 bucks less, but it had less pins in the DVI connector, therefore I assumed it would be a worse cable) (Kind of like paying extra for a theoretical instantaneous delivery from newegg) And don't be so rediculous as to run your 1900 x 1200 monitor with the 15-pin D-SUB VGA cable.
3)
If you wan to play Xbox on your LCD, avoid the Soyo.
4)
Strangley, the Westing house internal circuitry does sqeal a little bit. This happens in two instances. One sound is emmitted any time I have 120 volts applied to the panel. A second sound is emmitted when I have the brightness lower that 100. You won't be able to hear this if you have a desktop with any sort of fan inside, or if the room isn't 100% quiet. This, as of now, is my only only cause for concern on the Westinghouse.
****Update*****
Image Quality:
Read Here
Gaming:
OSD:
Viewing Anlge:
Miscellaneous:
1)
2)
3)
4)
