quick DOS command question
lukeh182
what does the command FORMAT D:/U do?? this would be on a HD with D being a second partition
KaosDG
/U
Specifies an unconditional format of a disk. Unconditional formatting
destroys all existing data on a disk and prevents you from later
"unformatting" the disk. You should use /U if you have received read and
write errors during use of a disk. For information about unformatting a
disk, see the UNFORMAT command.
