macrospect
- Nov 22, 2004
Well, after staring at that boring grey primer on the inside of my CM Stacker case, I finally decided to paint it up. I took all of my hardware out of it, and removed what seemed like 80 screws (Kudos to CoolerMaster for using a lot of screws, and not rivets). Also, for those areas where there are rivets, they are easy to remove (IE the PSU bay). I also have a rivet gun so there will be no issues when I go to put it back together.
Anywho, I got the case down to its bare bones. From there I took some 300 grit and gave it a good sanding (figured I would start with bare metal). I sanded for about 4 hours tonight, then called it quits. I will go back and finished some of those rough areas, and give it a good bath.
Now, I must decide what paints I am going to use. In the past I have used DupliColor's paints. I have been impressed with their results. First thing I need to figure out is what primer I am going to use. Since I am going to be painting the inside black (to match the rest of the case), I was hoping to find a black primer. I have been reading regular primers really dont work that well on bear metal. I know Qtip and a few other members mentioned somewhere that self-etching primer should be used. I really want something which bonds well to the metal. What are your guys thoughts on this? I know DupliColor only makes self etching in that ungodly brownish green, but hopefully with enough coats will prevent that from ever show through (the reason I wanted to use black primer, is if it scratch the inside somewhere, I want it to be somewhat discreet).
From there its just a matter of painting it with the main color. I think I am going to go matte black (again to match the outside), but I dont know what my options are as far as paint goes.
For those of you who have painted your cases matte, do you use a clearcoat when you are all finished? Any ideas if DupliColor matte clearcoat even exists? How about MATTE clearcoat enamel?
Thanks for any comments.
Oh, and I will try and post some pics up tomorrow. Should show a better idea of what I am talking about.
