Ok... so I am a programmer(well DevOps... I maintain most of our Linux servers also) and not a network dude... so please don't bite my head off.
As it sits right now I have a single Netgear wndr3700v3 running one of the latest versions of DD-WRT. One of the reasons I threw DD-WRT on it was for the QoS... I quickly found out that the QoS absolutely kills the poor 480mhz processor in my wndr3700 once I pass the 40mbit threshold of incoming WAN traffic.
So I grabbed an old low power Dell from work and a low profile pcie dual gigabit Intel NIC off eBay.
I'm trying to figure out what the proper configuration should be for my network now that I will have pfSense incorporated...
What I think(?) is right:
WAN(Comcast - SURFboard SB6141) => Input on Dell running pfSense
Output on Dell running pfSense => WAN on Netgear WNDR3700
^ that part is pretty obvious...
What I was wondering is how should I configure the WNDR3700? Obviously I will setup DHCP on the outgoing port for pfSense...
So thoughts on the WNDR3700:
- disable firewall
- disable DHCP and let pfSense handle?
- change my WAN port to vlan0? which is what my four ethernet ports are assigned to
- do I need to change the operating mode of the WNDR3700?
Another thought... should I just roll the WNDR3700 back to factory firmware since I don't believe I really need anything from DD-WRT with pfSense being in front of it?
Is this right? is there a better configuration? bueller? anyone?
- disable firewall
