publik_en3my
- Apr 17, 2004
Dear bros,
I want a stable current for my rig. That's why I buy the TrueBlue 480W from newegg. I got my relative bring it to VN
My rig comprises of:
+ ABIT IC7
+ P4C 2.4 Vcore DF
+ 256MBx2 Corsair TwinX @ Volt DF
+ Raddy 9800 Pro
+ 80GBs Maxtor SATA
+ DVD-ROM Lite-On
+ 1 FDD
+ Fan: 1 x 120mm fan, 0.31A, 1 x 120mm fan 0.45A, 1 x 80mm fan 0.19A
However, the 12V line seems not to be constant. The monitor software shows it only @ 11.8V when idle, as bad as @ 11.7V when PC is at load. Even I use the multimeter to measure, it is not a constant, it is changing from 11.9xV to 11.8xV. While the 12V line of TrueBlue of my friends here are stable.
Would you guy tell what the hell goin' on with my PSU? Do I need to change to TrueControl for a stable current?
+ ABIT IC7
+ P4C 2.4 Vcore DF
+ Raddy 9800 Pro
+ 80GBs Maxtor SATA
+ DVD-ROM Lite-On
+ 1 FDD
