Airbrushkid
- Aug 27, 2007
I am running a VPN on my main pc. Can I run another pc behind the main pc that has the VPN? Or do I have to put a VPN on the second pc?
Thank you
Thank you
which vpn? most paid ones support 5+ devices on one account. so youd just install it on the other pc.I am running a VPN on my main pc. Can I run another pc behind the main pc that has the VPN? Or do I have to put a VPN on the second pc?
Thank you
if you have a second network port on your vpn computer, or add one, you could try internet connection sharing(ICS)That's not a problem the pc I want to run behind my main is a windows 7. And the stop supporting it.
Putting aside the dubiousness of still running Win7 or continuously using a VPN...
I would suspect, but can't confirm, that Windows Internet Connection Sharing would allow you to place the Win7 box behind your main system and utilize its VPN connection. You may need a second ethernet NIC in the main and connect the other PC directly to it (been a long time since I've messed with the built-in connection sharing).
A better option might be to get a router that has its own VPN client support.
Well running Windows 7 is nothing wrong with doing it. Never had a problem with the OS just hardware that had nothing to do with the OS!! I am so glad you trust Microsoft with your info that keep making their money off of!!! Been using VPN 's for the last 8 - 9 years.
As for VPN providers, they offer no inherent security. About all they're good for is utilizing possibly-sketchy open WiFi or shifting your apparent location to stream geo-locked content. They can obscure your behavior from your ISP, but all you're doing there is moving that collection to the VPN provider itself.
All the same telemetry and other reporting in Win10/11 was backported into Win7/8 long ago. The only thing you've gained by continuing to run Win7 is an insecure system, as MS ended all support for the OS years ago.
one is software on your computers, the other is built into the router.Stupid here. Can someone tell what's different between a Router VPN and software VPN like from the ones you can get. Say NordVPN, ExpressVPN?
Honestly, if you don't really know what it is, then you don't need it. This the best explanation and is why I personally think these consumer vpn providers are just a scam unless you have a use case where you need one:I bought a new Asus RT-AX1800S. Never tried to figure out the VPN on the Router. I always paid for a service. I have a VPN Server, a VPN Client and Instant Guard and all 3 have PPTP, OpenVPN an IPSec VPN. Don't really what any of this is and how to set up.
SamirD
All I can say is fool and his money if you're trying to do something and don't even understand why you're doing it.Well I don't tell you what you need or don't. My opinion is like yours. Everyone has one. And everyone cannot speak for the others! I ask for help not to be told what to do that has nothing to do with what I am asking. I am sorry.
To set up your vpn to a vpn service you will need a vpn client (which you have) and then follow the instructions of the provider as they all use different methods--pptp, openvpn or ipsec. But be prepared to spend some time as I've set up IPsec vpn tunnels between our sites and even I found vpn provider's instructions to be lacking.
Welcome. Post back if you have any issues or further questions. I haven't done consumer vpn tunnels so a learning opportunity for me.Thank you.
It's actually the owner of the public IP that gets the notice and in turn notifies the user. The fact the IP owner is usually the ISP is just circumstance.And?
It's the ISP that emails if you do something naughty, not an upstream VPN provider. They work exactly as intended and work well.
