Questions about Silverstone SG16-Rig: Full AMD Build (CPU 7600X & Graphics RX 6750 XT)
RoddY
Hi guys!
My old ITX-system is nearly dead after 9 years and I need to build a new one. I did not follow the development of the last years in detail, so I am a bit off with current technology. Can you please give me some advise to my currently planned system? As I am concerned about CPU (105 Watt) and CPU-Cooler.
Usage: Gaming in 1440p (Max Details) or 4k (Medium to Max Details)
Case: SilverStone Sugo 16 Black
Main Board: MSI MPG B650I Edge WIFI
CPU: AMD Ryzen 5 7600X --> Question here is, if it is not overkill to have an 105 Watt CPU in that tiny case?
CPU-Cooler:
Thermaltake TH120 ARGB Sync --> Question here is, if it is able to keep the CPU in acceptable temperature ranges?
Thermal Paste:
Alphacool Subzero
Graphics Card: MSI Radeon RX 6750 XT Mech 2X 12G OC, 12GB GDDR6, HDMI, 3x DP (V399-004R)
PSU: SilverStone SFX Series SX700-G (Rev. 1.1)
RAM: G.Skill Flare X5 black DIMM Kit 32GB, DDR5-6000
Main SSD for the operating system: Western Digital WD BLACK SN770 NVMe SSD 2TB, M.2
Mass Storage: Samsung SSD 870 QVO 4TB, SATA
Operating System: Microsoft Windows 11 Home 64Bit
pendragon1
Extremely [H]
eh, you can make it work
yeah, sorta. it will work and will be withing spec but it will be quite toasty and wont boost as high for as long.
a ps120se or pa120se would probably be better than a 120 aio. they hang with 240mm aios.
Reactions: RoddY
RoddY
Hi pendragon1!
You maybe right that it could be too hot in there. My option could be to go with the Ryzen 7600 (without X) and overclock it a bit with AMD’s Precision Boost Overdrive (PBO). As cooler then the Noctua NH-L9a-AM5 would be possible as it seems to be sufficient enough.
This I would combine with the following fan setup:
TWO Arctic P12 PWM (One in the Front as output fan, One in the rear as input fan - sounds to be a bit strange, but the airflow in this case is somehow designed back to front, as the PSU-fan-output goes to the front...)
COMBINED with this Phobya fan distributor, as the MoBo only has cpu_fan (24 Watt), sys_fan (12 Watt) and pump_fan (36 Watt) - so I could control front and rear fans with the sys_fan connector (I believe at least?): https://www.amazon.co.uk/dp/B00OD7M...ZP&creativeASIN=B00OD7MO6E&tag=geizhals-am-21
OR does an 4-pin PWM-Y-Cable also work on the sys_fan connector to control the fron and rear PWM-fan?: https://geizhals.eu/noctua-na-yc1-chromax-black-a2308913.html
BR RoddY
pendragon1
Extremely [H]
Hi pendragon1!
BR RoddY
you can if you want but i wouldnt limit yourself with a low profile heat sink like that, you have the room in your case for a proper sized heat sink. you dont need any extra fan control. you have 1 front, 1 back and your cpu. if you end up with a heat sink that has dual fans, like id still recommend, it will come with one.
