Delicieuxz
- May 11, 2016
There's a 2021 version of the 1000 watt RMX, and a newer one, presumably 2022. The 2021 version is being price-dumped pretty hard right now.
2021 one:
https://www.amazon.ca/CORSAIR-SeriesTM-RM1000x-Modular-Supply/dp/B08R5PH1VY/
Newer one:
https://www.amazon.com/CORSAIR-RM1000x-Certified-Modular-Supply/dp/B015YEI7LK/
Anyone know what the difference between them is, other than the more stylish sticker on the newer one?
The 1000 watt PSU is longer than lower wattage PSUs.
850 watt PSU dimensions: 6.3 x 5.91 x 3.39 inches
1000 watt PSU dimensions: 7.08 x 3.38 x 5.9 inches
Will typical PC cases fit either side just fine? Will a higher wattage PSU operate at a cooler temperature under a given same load?
2021 one:
Newer one:
